7x16 V-nose
Re: 7x16 V-nose
Postby pbmazda32 » Fri Apr 19, 2013 6:59 pm
Looks fantastic. I think I'm gonna steal your E track bed idea. Do you think you could post a close up picture of how you mounted the bed?
pbmazda32
Re: 7x16 V-nose
Postby wtcreaux » Fri Apr 19, 2013 10:20 pm
The hardest cut was the first one. STRONGLY recommend NOT using a Sawzall....the result was a little more less finished than I would have liked
104971
104969
Vent hose mounted to the floor
104970
marine toilet .....waterless.....NO blackwater/ grey water, or fresh water
104967
E-track on the sides at 22" high. Used 2x4 lumber brackets to hold 1.25" x 1.25" 14 ga tubular steel, cut at 79". There are a total of three 1/2" plywood decks. The top one (38" x 79") has a 5" twin topper on it covered in Marine Vinyl (on sale at Joann's Fabrics, less than $30). The top one will move to the upper Etrack (with 3 steel supports) leaving the lower two (40" x 79") to slide forward (moving the supports also). A queen air mattress will fit on this.
104968
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby wtcreaux » Wed Apr 24, 2013 10:29 pm
Using Etrack along wall as previously described, use the lumber holders, the metal tubes are 1.25" x 1.25" 14 ga steel
105383
1' wood blocks lift the square tube
105384
3 twins
105386
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby wtcreaux » Wed Apr 24, 2013 10:32 pm
Security bar locked across RV latch
105377
Stainless steel eye bolt
105378
bolt fits between security handle and bar
105379
Lock moved to hole in handle and eye bolt......shouldnt have any surprises.....this also results in the bar being angled just right as a handle for assisting in and out......
105380
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby wtcreaux » Wed Apr 24, 2013 10:41 pm
Alternative to whole-vent fan is a computer fan, this one is a 120mm fan ($11 at Amazon) and moves ~ 90cfm on high.
105381
Toggle switch at AutoZone
105382
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby Rainier70 » Sat Apr 27, 2013 7:21 pm
Looks amazing! Nice work.
Rainier70
Images: 244
Re: 7x16 V-nose
Postby wtcreaux » Sat Apr 27, 2013 7:30 pm
Rainier70 wrote:Looks amazing! Nice work.
Thanks.....just taking my time and using ALOT of ideas folks smarter (and more talented) than I :)
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby wtcreaux » Sun May 05, 2013 9:27 am
100 amp circuit breaker......the red wire is from the solar controller
105854
Must have done something right :D , ALL green lights.....
105853
solar cables entering side of trailer with LOTS of silicone caulking
105852
MaxxAir II vent covers and solar panel (100w) - Ebay
105851
Mounting solar panel....used lumber strap and rebent it to form the Z-mount (a LOT less money) with plenty of caulking
105850
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby daveyd007 » Thu May 09, 2013 1:30 pm
You guys are doing a great job. I love the cabinet installation and its color. Did they come pre-finished like that? It's beautiful! :thumbsup:
daveyd007
Images: 29
Re: 7x16 V-nose
Postby wtcreaux » Sat May 11, 2013 8:16 am
Davey,
Bought them at Lowe's - Cheyenne - 2 - 24" base cabinets and 2 - 18" wall cabinets.......the counter to is a 6' prefinished formica from Lowe's
Thanks for the compliments......even my wife was surprised how well it's turning out :D
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby wtcreaux » Mon May 27, 2013 11:02 am
Xantrex 600w Pure Sine Inverter - used for some office equipment (printer/scanner)
107296
MOST important part (coffee pot) and microwave (750 watt) which plug into the 120v power strip (was able to use microwave, coffee pot, and refrigerator from my daughter's dorm room to see how it'll work).
107295
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby wtcreaux » Sat Jun 22, 2013 2:05 pm
30" vanity from Lowe's
108520
2 - 7-gallon water containers from Dick's, prevented from sliding forward by bar
108521
108522
Quick-Connect garden hose couplings to allow for changing tanks
108523
Pipe strap securing the vanity top from sliding
108525
Using a Shurflow pump for water delivery
108526
Electric switch to prevent pump from inadvertently emptying tank if leak develops
108524
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby OverTheTopCargoTrailer » Sat Jun 22, 2013 3:02 pm
Anyway to make the pics a little bigger for us old and almost blind folks :o :o :o
Thanks Jerry
Re: 7x16 V-nose
Postby cpinetree » Sat Jun 22, 2013 4:17 pm
OverTheTopCargoTrailer wrote:Anyway to make the pics a little bigger for us old and almost blind folks :o :o :o
Thanks Jerry
Try clicking on them, it works for me. :D
cpinetree
Images: 18
Re: 7x16 V-nose
Postby OverTheTopCargoTrailer » Sat Jun 22, 2013 5:50 pm
Sorry it only makes them marginally bigger .....
works half ars on my 27" monitor ....
but really tinny on my ipad or iphone :cry: :cry:
Jerry
