question on removing interior plywood
Re: question on removing interior plywood
Postby Rainier70 » Sun Feb 09, 2014 12:20 pm
I was able to reuse my plywood by adding a small #10 washer on with the screws. Putting it back up was fairly easy as the wood was already cut to size and the screw holes already "drilled" by the nails.
Rainier70
Images: 244
Postby roadinspector » Sun Feb 09, 2014 4:07 pm
Banjo wrote:Don't know if I will tear all the plywood off or not . I will not be camping in cold weather. Bob
Insulation will make a difference for you come warm to hot weather too and it is also sound deadening. I wasn't able to knock it all out but it helped make a rain sound like a rain on a tin roof instead of a hail storm. :)
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby roadinspector » Sun Feb 09, 2014 4:13 pm
Rainier70 wrote:I was able to reuse my plywood by adding a small #10 washer on with the screws. Putting it back up was fairly easy as the wood was already cut to size and the screw holes already "drilled" by the nails.
DUH, such a simple fix, Good idea!! Time & cost saving in one simple move! Thats why I like this forum, sharing of good ideas. I didn't have this problem but it will come in handy for other stuff. Thanks!!
Earnest
roadinspector
Images: 127
Postby RWH » Thu Feb 20, 2014 4:06 pm
You could also use a snap washer and then cover with a button for a cleaner look. :D I have seen these in big box stores and Ace HW.
Cargo Trailer Conversion Toy Hauler Conversion
My Prospecting Videos Videos By Muddog Productions
RWH
