Banjo wrote:Don't know if I will tear all the plywood off or not . I will not be camping in cold weather. Bob
Rainier70 wrote:I was able to reuse my plywood by adding a small #10 washer on with the screws. Putting it back up was fairly easy as the wood was already cut to size and the screw holes already "drilled" by the nails.
