8.5x 20 Cross Trailer conversion.
Re: 8.5x 20 Cross Trailer conversion.
Postby monocog » Tue Jun 09, 2015 9:46 pm
132778132777132776132774132775
monocog
Images: 20
Postby rebapuck » Tue Jun 09, 2015 10:18 pm
How wide is that side door?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby monocog » Wed Jun 10, 2015 6:16 am
42 inch side door.
monocog
Images: 20
Postby McDave » Fri Jun 12, 2015 3:53 pm
Where did you get your awning from? Price?
Thanks, McDave
McDave
Images: 412
Postby monocog » Sat Jun 13, 2015 11:00 am
McDave, I got awning at tristate surplus out of Hudson,Mi cost was 576.
monocog
Images: 20
Postby lrrowe » Sat Jun 13, 2015 11:21 am
Thanks monocog,
Thanks for the lead. I just checked them out. They do not have what I want now in stock, but I will keep checking their site.
Bob
lrrowe
Images: 439
Postby McDave » Sun Jun 14, 2015 10:49 am
Thanks for the info. I'll check them out.
McDave
Images: 412
Postby monocog » Sun Jun 14, 2015 8:44 pm
Give them a call, they don't have much on website.
monocog
Images: 20
Postby monocog » Sun Jun 14, 2015 8:55 pm
Took trailer out on maiden voyage, rained like crazy, pulled well, was happy to have awning. Decided I'll get.some new spring seats, and put springs over axles. Re installed large window, reduced amount of butyl tape used, seated much better.
monocog
Images: 20
Postby monocog » Sat Jun 20, 2015 3:50 pm
I bought dexter over under kit from etrailer, wasnt able to find spring seats or ubolts locally. Gained 7 inches of clearance on trailer. Tires look tiny, had to buy a step and Jack extension for tongue.
monocog
Images: 20
Postby monocog » Sat Jun 20, 2015 3:55 pm
133133133134133135
monocog
Images: 20
Postby monocog » Sun Jun 28, 2015 12:08 am
Haven't made any exciting improvement. Welded stabalizer jacks on, got a new hitch, last window in. I got a single step I need to put on in am. Got 3 gallons of herculiner for ramp, beavertail and "garage" section. Took it out for 5 nights with my family, mom, brother, sister nieces and nephews. Am planning on doing herculiner tomorrow am, need to insulate tailgate prior, what are your thoughts on doing vinyl plank flooring, the floating tone and groove type with quarter round trim around edges? Would be pinned down at transition from bedliner across width of trailer and at the step up from side door.
monocog
Images: 20
Postby msnglinc » Mon Jun 29, 2015 7:48 pm
monocog wrote:Haven't made any exciting improvement. Welded stabalizer jacks on, got a new hitch, last window in. I got a single step I need to put on in am. Got 3 gallons of herculiner for ramp, beavertail and "garage" section. Took it out for 5 nights with my family, mom, brother, sister nieces and nephews. Am planning on doing herculiner tomorrow am, need to insulate tailgate prior, what are your thoughts on doing vinyl plank flooring, the floating tone and groove type with quarter round trim around edges? Would be pinned down at transition from bedliner across width of trailer and at the step up from side door.
LVT flooring is what I am leaning towards as well. We had it installed in our offices last year at work and it has held up great in a tuff environment.
7 x 26 Cargo Craft V Nose
viewtopic.php?f=42&t=63350
msnglinc
Postby monocog » Thu Jul 02, 2015 8:28 pm
Good to hear. Thanks msnglinc. I got a few things done this past week, put in a step, porch light, 3 coats of herculiner on ramp area and 8 feet into trailer. Not real impressed with the herculiner, splotchy, chunks of large rubber in second gallon.
monocog
Images: 20
Postby monocog » Fri Jul 17, 2015 9:44 pm
I have made some progress, for some reason I can't post pictures right now. Working on a rear bed that pulls up to cieling when not in use. Walls are 1x2 18 gauge steel, 16 on center, having a hard time deciding if I need to reinforce walls at that point or if I need to just run either unistrut or steel tube all the way to floor. Set up would be like happijac, except manual.
monocog
Images: 20
