7 × 20 Aluminum
Re: 7 × 20 Aluminum
Postby Thumbbilly » Sat Jun 11, 2016 11:14 am
Walls are finished. Ceiling insulation is in, actual ceiling panels will be installed tomorrow.......progress.
Sent from my SM-G900R6 using Tapatalk
Thumbbilly
Re: 7 × 20 Aluminum
Postby CoventryKid » Sat Jun 11, 2016 3:23 pm
Thumbbilly:
That's one sweeeeet trailer you have there. With the size of your 2 toys, I'm really curious as to what your finished camping setup will look like.
Have fun!
Thanks for sharing! :thumbsup:
Doug
Vancouver Island, BC
CoventryKid
Images: 130
Re: 7 × 20 Aluminum
Postby m.colley » Sat Jun 11, 2016 5:28 pm
Looking good. Progress is a good thing. Have fun with your project.
Martin
m.colley
Images: 83
Re: 7 × 20 Aluminum
Postby Thumbbilly » Sun Jun 12, 2016 7:36 am
CoventryKid wrote:Thumbbilly:
Have fun!
When used for camping, it will only be with one toy. I am building a fake wall for inside the front ramp door to mount a window a/c unit......should be a fun work in progress!!
Thumbbilly
Re: 7 × 20 Aluminum
Postby Thumbbilly » Sun Jun 12, 2016 12:13 pm
Panels are up....just finish putting trim back up and on to next project.
Thumbbilly
Re: 7 × 20 Aluminum
Postby aggie79 » Tue Jun 14, 2016 12:14 pm
Looks really nice! :applause: :thumbsup: :applause:
Do you mind a few questions, please? What material is the wall/ceiling panels - aluminum, FRP? How are the panels attached to the framing? What is used to cover the panel seems - aluminum strap?
Thank you and keep up the good work.
Re: 7 × 20 Aluminum
Postby Thumbbilly » Tue Jun 14, 2016 12:22 pm
The panels are luan board (flooring underlayment) They are attached with self drilling screws. The wall seems are aliminum joints stuck to trailer with adhesive from the factory, ceiling is 1inch x 1/8 inch flat aluminum with screws thru it.
Thumbbilly
Re: 7 × 20 Aluminum
Postby rmcrist » Tue Jun 14, 2016 9:18 pm
Great rig! Can you tell us where you purchased your trailer and what brand?
rmcrist
Re: 7 × 20 Aluminum
Postby Thumbbilly » Tue Jun 14, 2016 9:21 pm
The brand is Lightning. I purchased it thru Swartz Trailer Sales in Michigan. The trailer was built in Indiana.
Thumbbilly
Re: 7 × 20 Aluminum
Postby Thumbbilly » Thu Jun 16, 2016 7:46 pm
Removable interior wall is mounted and air conditioner is functional. Just open ramp door and turn it on.
Thumbbilly
Front Ramp Room
Postby CaptD » Sun Jun 26, 2016 12:11 pm
Like your idea. I'm doing almost the same thing with a wall/bulkhead going widthwise. Window A/C mounted up high (in a window so I can just use the window when cool out) and propane heater installed below. Run a closet rod across to hang wet clothes to dry out, propane storage locker, spare tire, jack and safety cones, car wash items, ladder, leveling blocks, folding chairs, mat for under canopy, grill. Install a 12v bug light (yellow) and don't forget about making use of that front ramp. I'll be using mine as a table - for meals and cooking, breakfast bar, etc as well as an outdoor project table. Cover with a heavy duty canopy grade silver tarp to keep the food spills contained (think BEARS). Get a couple of aluminum folding walkers with adjustable height legs at the thrift store/yard sales to level off the ramp. CaptD.
2015 Pro Line 7x7x24
2001 Ford E 250
2011 WR 250R
2007 KLR 650
2007 TW 200
CaptD
Re: 7 × 20 Aluminum
Postby hankaye » Sun Jun 26, 2016 12:17 pm
CaptD, Howdy;
One thing to remember is that propane needs external ventilation. My propane tanks
are inside compartments but the bottoms are just a big hole. Propane is heavier than
air so it needs to be able to vent to the outside below the tank(s). Just something to
think about ...
hank
hankaye
Propane
Postby CaptD » Sun Jun 26, 2016 1:01 pm
Yep. Thanks Hank. Used to know a guy who did Coast Guard safety inspections on boats/yachts and he told me that propane is similar to water as it wants to search out the lowest areas. He would open the propane locker and pour in a couple gallons of water. If all the water ran out (in a timely fashion) the propane locker passed inspection. So no vents on the top or sides and plenty of open floor on the bottom of the propane locker like yours. Thanks again Hank. I always welcome other folks input especially when its safety related. CaptD.
2001 Ford E 250
2011 WR 250R
2007 KLR 650
2007 TW 200
CaptD
