Adding a Voltmeter to check Battery Status
Re: Adding a Voltmeter to check Battery Status
Postby Shadow Catcher » Sat Feb 04, 2017 9:54 pm
A volt meter is only accurate when the battery has been at rest, no in or out for a few hours.
Postby flboy » Sun Feb 05, 2017 9:02 am
Shadow Catcher wrote:A volt meter is only accurate when the battery has been at rest, no in or out for a few hours.
That is correct in a perfect world/lab. The use of the battery distorts the voltage curve and they should rest for at least 4 hours. Lithium batteries, because of their flat discharge, are even harder to determine with a voltage measurement. However, for the purposes of an RV and trying to make sure your lead acid batteries don't go below 50%, "monitoring" your batteries with a voltage based measurement is good enough and very inexpensive.
A hydrometer is not practical in an RV on a ongoing basis and the coulomb counting and the impedance spectroscopy methods can be expensive in terms of the monitors. I believe some very expensive controller/chargers may use those methods via internal computers. If I spent the money for lithium batteries, I'd buy a better monitoring system; however, the lithium batteries can be drained almost 100%, so the inverter will monitor it and shut down at 10.5 volts and the charger will stop charging when full.
The meter I have basically tells you how many amp hours I have used, however, it also is charging continually in the sun... so I just keep an eye on the voltage to make sure it stays in a good area, especially under and a moderate load. The Hydrometer can be used to check the battery health periodically (once a month) when I check the water levels since I am using lead acid batteries (that's why I like the FLA over the AGM or Gel also... plus they are very cheap relatively and last a long time if cared for properly).
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby John61CT » Sun Feb 05, 2017 10:40 am
SmartGauge works fine, believe that can be found for under $200 delivered
John61CT
Postby low277 » Sun Feb 05, 2017 12:32 pm
Simple battery gauges aren't perfect but they are very commonly in use on battery powered equipment. Golf carts, scissor lifts, boats and RVs. There are better more expensive gauges, meters, but for most everyday users they get the job done at a affordable cost. :) I like simple! Simple is good!
NW Minnesota
low277
Images: 5
Postby bdosborn » Sun Feb 05, 2017 1:21 pm
I used to check my teardrop with a voltmeter when I got up on the morning as the battery was at rest for 8 hours or so. I could easily go a weekend without having to worry about discharging a fully charged battery too much so checking it wasn't really required till I went on longer trips. Then I upgraded to a 12v DC fridge and installed a Trimetric meter to keep a closer eye on things. However, a typical teardroper doesn't use their battery at night like we do with our fridges and heaters. ;)
Images: 806
Postby flboy » Sun Feb 05, 2017 1:32 pm
low277 wrote:Simple battery gauges aren't perfect but they are very commonly in use on battery powered equipment. Golf carts, scissor lifts, boats and RVs. There are better more expensive gauges, meters, but for most everyday users they get the job done at a affordable cost. :) I like simple! Simple is good!
:thumbsup: :thumbsup: :thumbsup:
Don (Flboy)
flboy
Images: 378
Postby cdub » Mon Feb 06, 2017 8:47 pm
I purchased a drok power meter for mine so I can see volt and amperage. I have tested it but not permanent mounted yet. Where on Van isle are you as I am in Parksville ?
cdub
Postby vincigj » Wed Feb 08, 2017 10:57 am
I use a voltmeter/ clock/thermometer all the time. Voltmeter is just for trending. Don't need lab quality for that.
vincigj
Postby CoventryKid » Wed Feb 08, 2017 2:26 pm
cdub:
Where did you get it? Locally??
Thanks!
Doug
Vancouver Island, BC
CoventryKid
Images: 130
Postby cdub » Wed Feb 08, 2017 2:37 pm
I bought it through ebay as the amazon US store wont ship to Canada, and the amazon Canada site didnt have the meter i was looking for.
https://www.amazon.com/gp/product/B017B ... multimeter
hopefully I am allowed to post links.
cdub
Postby CoventryKid » Wed Feb 08, 2017 6:14 pm
Thanks, cdub. Yeah, links are good!
Doug
CoventryKid
Images: 130
Postby flboy » Thu Feb 09, 2017 8:30 pm
I am using those meters also and they work great. The link was for a 50A shunt. Make sure you get one with a shunt for the right amount of current. If you are running an inverter greater that 500W, that meter and shunt will not measure beyond 50A. The voltmeter doesn't care. If you are just running lights and a few small things... that probably is fine.
I got the 100A shunts because I use a larger inverter and it will almost all of that if I am pushing it.
Don (Flboy)
flboy
Images: 378
Postby cdub » Fri Feb 10, 2017 11:00 am
How did you mount the meter?
I am looking at using a Decora style Nylon plug cover and trying to cut to size. They didnt leave much area for the locking tabs to grab onto.
cdub
Postby CoventryKid » Fri Feb 10, 2017 3:33 pm
cdub:
I haven't mounted the meter yet as I'm thinking I'll try and find something a little simpler - like a meter that does not require power. As Don (flboy) mentioned, he wondered whether 12V to power this meter might harm the meter (when it says it requires only 5V to power it).
As I mentioned, I'm good at wiring, just not good at electronics - I think I'd rather find a meter with 2 leads and use the KISS method.
However, to answer your question, the meter I have is a "snap-in" type - just cut a hole the right size and pop it into place which is what I want to do. It has retaining tabs on the side so no cover plate is required.
WTH, I may just try wiring it with 12V and see what happens. If it works, great. If not, plan B explained above.
Doug
CoventryKid
Images: 130
Postby cdub » Fri Feb 10, 2017 4:24 pm
Sorry i should have specified the question to ftboy as he used the same units I have.
The unit i bought is 6.5-100vdc so under over voltage isnt an issue.
The unit you have could be powered from a USB adapter as i believe they are 5volts.
cdub
