New Build - 6*12 Offroad Toy Hauler
Re: New Build - 6*12 Offroad Toy Hauler
Postby Gulfcoast » Sat Jun 19, 2021 8:25 am
I use this site, it has about every free campsite in the USA listed:
https://freecampsites.net/
https://www.campendium.com/national-parks
6x12 cargo trailer - Mini Split A/C - Starlink
Gulfcoast
Postby flboy » Sat Jun 19, 2021 8:45 am
Thanks Hank and Gulfcoast. Much appreciated!
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Sat Jun 19, 2021 9:46 am
There they are. Just getting them ready for pairing. 510 aH useable at 94lbs which is better than 8 GC2 golf car batteries at 448 lbs.
Just love the newer technology that is now affordable for the DIY'r. This setup as I bought it and built it cost me about $150 more ( maybe less since I did not add in tax or core charges) than 8 GC2s at Sam's would be and will last 5x longer with no maintainance and charge significantly more efficient making best use of solar. Nevermind I'd have no room or would want to take the weight hit for the SLA batteries in this 6x12 or my 7x18 for that matter.
Can't wait to see what technology is next. Probably will be lighter, smaller, and more capacity again!
Don (Flboy)
flboy
Images: 378
Postby featherliteCT1 » Sat Jun 19, 2021 5:48 pm
Wow that looks good!!! :thumbsup: :thumbsup:
featherliteCT1
Postby flboy » Sat Jun 19, 2021 7:08 pm
Thanks
Started wiring in the circuits today.
Don (Flboy)
flboy
Images: 378
Postby Gulfcoast » Sun Jun 20, 2021 2:58 am
How many watts of solar are you going with?
Gulfcoast
Postby onehoser » Sun Jun 20, 2021 4:20 am
awesome work! :thumbsup:
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby flboy » Sun Jun 20, 2021 6:31 am
Gulfcoast, I have 2 210 watt panels for 420W total. Using a 30A MPPT controller in the 24V configuration.
I have more real-estate on the roof up front for a few more 100W panels. If I think I can use them, I may add them later on with a separate 20A controller. I like to have separate systems for redundancy in case I have a controller fail. This is primarily because I need to make sure the fridge always has power.
Onehoser, thanks.
Don (Flboy)
flboy
Images: 378
Postby hankaye » Sun Jun 20, 2021 9:30 am
flboy, Howdy;
Don, you always impress with your workmanship and innovations.
:applause: :thumbsup: :thumbsup: :applause:
hank
hankaye
Postby bdosborn » Sun Jun 20, 2021 11:58 am
flboy wrote:Image
Damn, that's a big battery. :applause:
Images: 806
Postby flboy » Sun Jun 20, 2021 1:38 pm
Lol.. thanks. Goal is to be able to run the A/C overnight in a parking lot when I am on the road with enough margin to keep the fridge and etc. going as well while it recharges. Should do it.
Don (Flboy)
flboy
Images: 378
Postby Gulfcoast » Sun Jun 20, 2021 1:49 pm
Here you go... a great solar panel calculator for RV's:
https://www.parkedinparadise.com/solar-calculator/
Gulfcoast
Postby flboy » Sun Jun 20, 2021 3:18 pm
The wires I added to the inverter do trigger the relay, so now I just need to run wires to a switch inside the cabin and I will be able to turn on the inverter remotely. I am putting the transfer switch inside as well along with all monitors, so I should not need to open doors and go onto electrical area unless I am having a problem.
This is where the big fuses are 250A for battery and 150A for inverter. I may be replacing the ANL for some higher end DC breakers. I do not like how hot they get when running 1500W inverter at max. That would be a rare load, but I still don't like it. I just had these in my cabinet, so I used them. The 80A breaker is just to protect the wire to the DC fuse panel. I like the breaker because I can disconnect just that while working on the other wired. If I need more than that, I have the main disconnect in view next to fuses.
The BMS will protect each battery at 150A for 300 total. I should never see a load close to that, so if I did, that would mean a good short on the buss bar and I'd want to protect the wiring. The BMS should protect the batteries.
Don (Flboy)
flboy
Images: 378
Postby flboy » Sun Jun 20, 2021 3:32 pm
Just have to connect the Converter, Solar Controller and the DC to DC charger to the bus bars and then I will hook up the 110VAC side of the power system.
I also need to build a strap to tie down the batteries. I have a thick rubber mat to set them on and then I will strap them down. I don't want them bouncing around on those rough roads.
Going to put it on hold for a few days. Going camping with the other CTC. Lex and my wife will be onboard for this trip.
Don (Flboy)
flboy
Images: 378
Postby flboy » Sun Jun 20, 2021 4:14 pm
hankaye wrote:flboy, Howdy;
:applause: :applause:
hank
Thanks Hank! Appreciate that.
Don (Flboy)
flboy
Images: 378
