pvangel wrote:kkayv wrote:Sorry...
One more question... where did you order the flooring?
I can't find the receipt for the flooring, I will try and look for it.
Found it! http://www.modutile.com/coin-interlocki ... -gray.html $2.00 a sq ft.
pvangel wrote:tnriverluver wrote:pvangel wrote:Thanks Hank! Table mounts on grommets that are on the inside and out, pops off in seconds and you can move it. I intend to use it for a grill stand /kitchen on the outside.
Anybody find an affordable roll out awning? I see them for $4-500.00 for a 12' one, seems like a lot?
Any ideas?
A bag awning for a pop-up is probably your best option for that trailer. They are easy to put up and take down with a little practice. It is what I went with on my build because I wanted to be able to open my door back all the way if needed and wouldn't be able to with a regular RV awning. Mine came from here http://www.rvworkshop.com/index.php/pro ... rkShop-844
Nice! Which one did you buy, the supreme or regular? do I buy a 10' one for a 12' trailer?
Thanks for your help!
225 wrote:Love the build.
Watch out for the HD cabinets. I had to readjust my drawers a few times. They kept jamming. And that was in my garage. I can only imagine them bouncing down the road.
I am a supermoto guy. So I figure that a SM is maybe 3" shorter than a dirt bike? What's the length of one?
tnriverluver wrote:A bag awning for a pop-up is probably your best option for that trailer. They are easy to put up and take down with a little practice. It is what I went with on my build because I wanted to be able to open my door back all the way if needed and wouldn't be able to with a regular RV awning. Mine came from here http://www.rvworkshop.com/index.php/pro ... rkShop-844
pvangel wrote:Can you tell me a little bit about the mounting? My trailer has a lifetime warranty against leaks in the roof as long as I don't compromise it.
I am wondering myself how it's mounted and how does it work? There website really doesn't show anything and none of the other manufacturers show anything?
tnriverluver wrote:pvangel wrote:Can you tell me a little bit about the mounting? My trailer has a lifetime warranty against leaks in the roof as long as I don't compromise it.
For any type of RV awning you have to put a track or channel on the trailer for the rope sewn into the edge of the awning to slide into. These awnings are contained in the bag when stowed and the bag is what has the edge sewn into. The track is on that website I posted and when you look at the pictures it will be self explanatory. It will require about 15 Screw holes inte the side or roof of the trailer, but easily sealed with RV type caulk. http://www.rvworkshop.com/index.php/cat ... ning-track
BC Dave wrote:waow; you dun!![]()
thanks for posting so many pics and showing your progress; I like your organized neat work.
awning - why not get one of those free standing metal framed fold up picnic awnings? I got a 12X12 X8ht that fits over my 6X10 CT. that way I can adjust the cover and sometime I wna t to shad the trailer in the heat. Just My 2 cents.
Happy trails !
now if the snow would melt!
