trailer wiring
Postby nitro_mt_racer » Wed Dec 28, 2011 3:00 pm
pete42 wrote:The Neil Armstrong airport isn't the same one I flew off of back in the 50's & 60's.
if you install a 30 amp power cord and need to plug it into a 120 volt 15 amp receptacle they make an adapter for that
in fact they make one that allows you to plug into a 50 amp receptacle as well.
"Never mix old and new, or Brand of, Circuit Breakers -> Panel Box whether price is an issue or not."
most if not all panel boxes only work with their own breakers, old used breakers do wear out so I too would use new ones specific for that panel box.
pete
Thanks for the info Pete. You almost had to be using that grass landing strip north of town back then.
nitro_mt_racer
