air conditioner
Re: air conditioner
Postby OverTheTopCargoTrailer » Wed Jun 08, 2016 1:56 pm
people here are using mini splits......
Come on bob you are pulling my leg RIGHT ?? :thinking:
post some links please
Re: air conditioner
Postby lrrowe » Thu Jun 09, 2016 6:38 am
Ok...others here are talking about using them and you for one have used them. Just used the search feature and could not locate one other I thought was using them. Ok?
Bob
lrrowe
Images: 439
Re: air conditioner
Postby Pleiades » Thu Jun 30, 2016 9:47 pm
Has anyone used the little tower ac units. Its what I was planning on using. The little emergency kind for your house when the main ac goes out. Has 4 inch flex duct to go outside.
Better to bring it and not need it...that whole thing.
Pleiades
Re: air conditioner
Postby OverTheTopCargoTrailer » Thu Jun 30, 2016 11:37 pm
I gotta admit it's great using this forum, you don't even need to read it anymore. Just pop in your question & out pops an answer. Right answer - wrong answer ? Does it really matter when your just looking for a fast & easy answer ?
Sometimes I feel bad for those who have spent countless hours documenting their efforts with endless details. Sometimes I feel bad having comitted those same offenses of adding boring information on topics no one wants to be overloaded with useless details.
If only I had known. :thinking:
Re: air conditioner
Postby Pleiades » Fri Jul 01, 2016 7:24 am
I like sarcastic smart×$!** myself
Pleiades
Re: air conditioner
Postby aggie79 » Fri Jul 01, 2016 7:40 am
Pleiades wrote:Has anyone used the little tower ac units. Its what I was planning on using. The little emergency kind for your house when the main ac goes out. Has 4 inch flex duct to go outside.
I'll have to get back with you later with links, but most experiences with portable air conditioners for cooling cargo trailers have not been good.
Re: air conditioner
Postby Pleiades » Fri Jul 01, 2016 7:47 am
Thank you for your patience and the lack of mine in searching the forum first. I did. Just maybe didnt know what to call them. I will look more. Again. Thanks
Pleiades
Re: air conditioner
Postby OverTheTopCargoTrailer » Fri Jul 01, 2016 7:47 am
Passt Aggie79
Stop giving away all the milk. Make them at least rent the cow for a week. LOL
Re: air conditioner
Postby OverTheTopCargoTrailer » Fri Jul 01, 2016 7:52 am
Pleiades
If your looking you could find the exact answer to that type of ac under my thread.
Overthetopcargotrailer
Re: air conditioner
Postby Pleiades » Fri Jul 01, 2016 7:54 am
OverTheTopCargoTrailer wrote:Pleiades
I knew you had it in you. That was nicer. Thank you
Pleiades
Re: air conditioner
Postby DrewsBrews » Fri Jul 01, 2016 8:24 am
The issue with the "portable" units is they typically have only a vent for the condenser exhaust, and no outside intake for it. Same issue as having a window unit mounted flush at the back: It draws the inside air that was just cooled and dumps it back outside. That air needs to be replaced somehow so you then need to draw hot outside air back in the cabin area. Doesn't make much sense as it is a much less efficient way of cooling. So you need a bigger unit in order to get the same (or less) cooling and use more power doing it.
DrewsBrews
Re: air conditioner
Postby McDave » Fri Jul 01, 2016 1:21 pm
Hey Pleiades,
Well played. :applause:
Also, I think Drew has it right. The same issue exists for fridges. You're really just pumping the heat around in circles, if you don't get rid of it, and isolate the condenser from the cabin interior.
McDave
McDave
Images: 412
Re: air conditioner
Postby Pleiades » Fri Jul 01, 2016 1:30 pm
McDave wrote:Hey Pleiades,
McDave
Thank you thank you. Your too kind. Well you an drewsbrews sure have brought some things to my attention i did not account for but will have to overcome. Thats what makes doing some research and having nice people to point things out so nice. :thumbsup:
Pleiades
Re: air conditioner
Postby OverTheTopCargoTrailer » Fri Jul 01, 2016 1:44 pm
drewsbrews
You just gave away our whole heard of Milk cows for free :cry: :cry: :cry:
Re: air conditioner
Postby Rainier70 » Fri Jul 01, 2016 5:51 pm
I don't have an air conditioner of any kind in my CT, so I can't help you with an experienced answer. But I can help a little with searching.
I have found the best way to search this site is by using the Google Advanced Search Function https://www.google.com/advanced_search?hl=en&authuser=0
Google Advanced has a field at the bottom of the search page where you can write in the "site or domain". If you type tnttt.com into that field, all of the answers it returns will be from here. For example I typed the site in and then searched for ---- air conditioner split. This is what it returned:
https://www.google.com/search?hl=en&as_ ... as_rights=
Rainier70
Images: 244
