roadinspector wrote:Don,
Thanks. I'm having fun building it. Yes I did have to cut a hole approx 3" diameter with a saber saw. No probs at all. I will need to put some insulation underneath the CT around the base to help keep the aluminum from getting too cold in the fall & winter. May get a small plastic bowl and fill it with spray foam then push it up over where it protrudes thru the floor. I'll secure the bowl with wood screws and call it good.
Earnest
That really sucks about the linoleum.![]()
I didn't use bamboo but I installed simular in my house. It was easy install and has lasted really well. Only concern I can think of is the typical expansion contraction problem that caused you linoleum to buckle. The laminate flooring is designed to be free floating so it should be fine as long as you leave expansion room on the edges. When you put the floor trim on just don't apply any down pressure that would keep the flooring from moving. I would like to use laminate flooring in my CT but I think my Harley would scratch it up and if I had any leaks it would damage it too.
Earnest
This one is actually one that doesn't unless there is a prob. Not like my old one did. It marked its territory every where it was parked. I enjoyed the harrassment from all the rice burners. They used to follow me just to pick up and give me back my parts that kept falling off!!If ya can't laugh at yourself go home.
Earnest
OverTheTopCargoTrailer wrote:OMG Big Daddy Don
Welcome back![]()
Jerry
