6X12 TA V-nose project
Re: 6X12 TA V-nose project
Postby wtcreaux » Wed Jun 24, 2015 7:15 pm
desertrat222 wrote:this is a great bed idea and a hole heck of a lot cheaper and easier then my beds were to build! :thumbsup:
Thanks desert, I had originally envisioned what you did but wanted to use the e-track......tried what cornfused did but couldn't seem to make it work, so......
wtcreaux
Images: 211
Postby wtcreaux » Sat Sep 12, 2015 11:56 am
I had originally posted this under the "electrical" section -- http://www.tnttt.com/viewtopic.php?f=30&t=63706
I have found an acceptable answer but have some expensive lessons to pass on.......
I used a C7 connector with a right-angle
http://www.ebay.com/itm/261784958512?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
the end looks like this 135917
This allows the cord to lay alongside the cooler
135915 135916
The lesson?? - CUT THE PLUG END OFF BEFORE GOING INTO TRAILER........I plugged the C7 end into the 12-volt plug on the cooler (the black wire is on the far end of the C7 which coincides with the black wire on the original cord (towards front of cooler)). Not thinking, I then plugged the corded end (120-volt plug) into the inverter with an immediate blown fuse. Checking the power supply, found it was shorted :x which cost me ~ $75 here http://www.ambientstores.com/productdetail/refrigeration___bar_accessories_and_parts/669
Summary - use a C7 right-angle connector and make sure your connecting end is for 12-volt
wtcreaux
Images: 211
Postby wtcreaux » Fri Oct 09, 2015 9:09 am
Found on pinterest this idea.......had some scrap ¾" plywood laying around
136554
136557
Now a step used for the rear cargo doors......makes it much easier on the knees when stepping up/down. Connected with two ⅜" carriage bolts (galvanized) with wing nuts
wtcreaux
Images: 211
Postby wtcreaux » Fri Oct 09, 2015 9:30 am
Sleeping platforms.......the platform on the R held a guy weighing 240 (I put 5 supports under). The platform on the L held a guy weighing 180 (4 supports). The sleeping pads are 3" inflatable foam pads from Costco.........worked ok but as I get older, the shoulders ache at night (yeah, I know - get 'em checked).....I'll be adding another 3" memory foam.
136558
wtcreaux
Images: 211
Postby wtcreaux » Fri Oct 09, 2015 9:31 am
Had some 2" conduit clamps laying around...
136555 136556
wtcreaux
Images: 211
Postby wtcreaux » Fri Oct 09, 2015 9:32 am
Fairfield State Park - Texas.......NICE place......
136559
wtcreaux
Images: 211
Postby wtcreaux » Fri Oct 09, 2015 9:44 am
The window shaker did fine. Kept the trailer at 64F without a problem. Also couldn't even hear the AC from the campsite (it was on road side). The next campsite over had a pop-up with rooftop AC. You could hear it in the background at night.
136560
133289
wtcreaux
Images: 211
Postby Gunman9 » Thu Oct 29, 2015 5:31 pm
Here is how I mounted my ac unit through the cargo hatch
Gunman9
Postby wtcreaux » Thu Oct 29, 2015 6:45 pm
Gunman9 wrote:Here is how I mounted my ac unit through the cargo hatch
Well done !! How does it work with driving down the road in rain?? (That was my only concern with placing it in the V)
wtcreaux
Images: 211
Postby Gunman9 » Thu Oct 29, 2015 9:13 pm
The attachment ImageUploadedByTapatalk1446157908.631952.jpg is no longer available
I remove it when I travel. It sits under the bench in the. This is where my breaker box and all my extension cables are stored as well. It rest on 5 mounts and bolts down. Easy on and easy off and ver secured. Here is where it's stored while moving
Gunman9
Postby wtcreaux » Wed Nov 25, 2015 7:02 pm
Added some trim to the table.......used ¾" U-channel.....used brazing to fill in the curve slots (1st time, so it's not the cleanest)
137665 137666 137667 137668
wtcreaux
Images: 211
Postby munchmeister » Thu Dec 31, 2015 11:17 pm
Nice work. Like the bracket beds. Inspiration!
munchmeister
