Updating your Hall of Fame entry
Postby john curtis » Fri Jun 25, 2010 2:46 pm
How do you change your profile picture in the Hall of Fame ?
John
john curtis
Images: 141
Postby planovet » Fri Jun 25, 2010 3:13 pm
Click on the Hall of Fame button at the top of the page. Find your teardrop and there is an edit button under the picture. Click on the edit button and change the url of your picture. This SHOULD work. I say this but when I tried it a while back it would not work for me. I ended up adding a new entry with a new picture and had Mike delete the old entry.
I hope it works better for you than it did for me.
ImageMark (& Cindi)
planovet
The Cat Man
H of F
Postby john curtis » Sat Jun 26, 2010 1:38 am
Thanks for the reply.Did just what you said for close to an hour and all I got was error , error, and more errors.
John
john curtis
Images: 141
Postby mikeschn » Sat Jun 26, 2010 6:38 am
Updating the Hall of Fame should be easy.
First find the edit button under your HOF entry...
This dialog screen should pop up...
Paste the link to the picture you want to use in the Picture URL line. The best place to get the picture link is from your Personal Gallery here on the forum.. just copy and paste it... (notice it has pic_id= somewhere in the line)
Paste the link to the album on the Album URL line. The best place to get this is when you are viewing your album on the forum. Notice, it should have the word user_id= somewhere in the line; again just copy and paste.
Finally, click on "Update User Info"
If you are getting an error message, I'd like to see a screenshot...
Thanks,
H of F
Postby john curtis » Sun Jun 27, 2010 5:40 pm
http://tnttt.com/updateImage.php?id=602
Ok I tryed and this is what I got.I also hope this address brings up the error pic.
Thanks John
john curtis
Images: 141
Hof F
Postby john curtis » Sun Jun 27, 2010 5:43 pm
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TD' WHERE user_id='7087' and id='602'' at line 1
Ok the first try didnt work so here goes again.
john curtis
Images: 141
Re: H of F
Postby mikeschn » Sun Jun 27, 2010 5:46 pm
john curtis wrote:http://tnttt.com/updateImage.php?id=602
Thanks John
No it doesn't bring up the error pic. Can you take a picture with your camera and post it in your album?
Mike....
Postby mikeschn » Sun Jun 27, 2010 5:59 pm
Is anyone else here on the forum getting this error message? I've edited my HOF entry, and everything works just fine...
Postby bg » Wed Jun 30, 2010 1:50 pm
I had the error until I deleted the apostrophe in the description.
Bobby(, Kim & Wayne)
bg
H of F
Postby john curtis » Thu Jul 01, 2010 1:07 am
Heres the error again.I tried to remove the aopstrophy but it dosnt show up in the lines when I cut and paste.It only shows up in the error message.Thanks John
john curtis
Images: 141
Re: Updating your Hall of Fame entry
Postby OzarkWonder » Wed Jan 28, 2015 6:32 pm
I have the same problem. I will try to post a picture.
- Kenton
OzarkWonder
Images: 50
