Insulation Thoughts?
Postby d30gaijin » Mon Aug 30, 2010 9:02 pm
I installed the blue 1" foam board insulation in the side walls and roof of my CT conversion, still I need to insulate the upper corners where the 12v DC electrical wiring runs to overhead lights and outside trailer lights (see pic below) and I am thinking that 2" woven type fiberglass insulation might be a better choice than the blue 1" foam board since those areas are closer to 2" in depth than the area between the roof and paneling and sidewalls and paneling are. That area will be finished off with Luan paneling at about a 45 degree angle so there should be plenty of room for the 2" fiberglass insulation.
Any thoughts?
Don
d30gaijin
Titanium Donating Member
Images: 139
Postby starleen2 » Mon Aug 30, 2010 9:04 pm
Should work and be just fine :thinking:
starleen2
5th Teardrop Club
Postby GPW » Tue Aug 31, 2010 7:09 am
Just a consideration ... You might want to wrap that fglas insulation (like a plastic bag ) , so no particles get shaken out on the road :o ... Easy to just fill some plastic contractor bags with fiberglass, or even cellulose , fold and tape and stuff in the openings and screw a cover over that ...the plastic bag also keeps the fiberglass dry , very important to it's insulating qualities... that's the way we used to do custom vans , some time ago... we even used to wrap the trim cover with matching carpet so the screws wouldn't show.. a bit excessive , I must admit... :roll:
Postby pete42 » Tue Aug 31, 2010 8:13 pm
On one trailer the builder used crown molding on the side as well as the top to hold the fiberglass in place sorta like you are describing.
pete42
Postby d30gaijin » Tue Aug 31, 2010 9:41 pm
GPW wrote:Just a consideration ... You might want to wrap that fglas insulation (like a plastic bag ) , so no particles get shaken out on the road :o ... Easy to just fill some plastic contractor bags with fiberglass, or even cellulose , fold and tape and stuff in the openings and screw a cover over that ...the plastic bag also keeps the fiberglass dry , very important to it's insulating qualities... that's the way we used to do custom vans , some time ago... we even used to wrap the trim cover with matching carpet so the screws wouldn't show.. a bit excessive , I must admit... :roll:
GPW,
Again, more excellent advice from you. Thank you for that! I was concerned with reports of fiberglass insulation and vibration, which was the reason for my question/this thread. Great idea to encapsulate it in plastic!
Don
d30gaijin
Images: 139
Postby vreihen » Wed Sep 01, 2010 6:04 am
d30gaijin wrote:Great idea to encapsulate it in plastic!
May I throw out a suggestion and suggest that you look at a roll of Seal-a-Meal "bags" in lieu of contractor bags and tape? The one that I have in my hand right now is essentially a plastic bag material tube that's 11" wide (flattened) and 18' long. All you need to do is seal the ends with double-faced tape or caulk after you stuff it with the itchy stuff, and all should be good (assuming that it fits in the space you're trying to fill).....
vreihen
Postby GPW » Wed Sep 01, 2010 7:28 am
Seal a meal ... that's a cool idea if you have one .... like little insulation pillows to stuff wherever you want ... 8) Great idea V !!!
Postby d30gaijin » Wed Sep 01, 2010 9:48 am
vreihen wrote:May I throw out a suggestion and suggest that you look at a roll of Seal-a-Meal "bags" in lieu of contractor bags and tape? The one that I have in my hand right now is essentially a plastic bag material tube that's 11" wide (flattened) and 18' long. All you need to do is seal the ends with double-faced tape or caulk after you stuff it with the itchy stuff, and all should be good (assuming that it fits in the space you're trying to fill).....
Vreihen,
Another excellent idea, thank you for that! And I actually have a Seal-a-Meal sealer. :lol:
Don
d30gaijin
Images: 139
Postby Arne » Wed Sep 01, 2010 12:05 pm
have a look here.. it is what I used in my ceiling... 4 layers = 1.5 inches.
http://www.discconnect.com/FoamFly/what.htm
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby GPW » Wed Sep 01, 2010 12:45 pm
Arne , I always reserve that stuff for my model airplanes ... http://www.foamfly.com/gallery2/v/Photos/Glen/
Too valuable for common insulation ... :o
Postby Arne » Thu Sep 02, 2010 9:55 pm
I worked out the sq. ft. price.. it is about the same as 1.5" thick rigid foam...
but, it probably does make great airplanes.... most small electrics are foam... I still fly the old fashioned way... with fuel and oil covered planes.
Arne
Mr. Subject Line
Images: 96
Postby vreihen » Fri Sep 03, 2010 6:12 am
Arne wrote:but, it probably does make great airplanes.... most small electrics are foam... I still fly the old fashioned way... with fuel and oil covered planes.
To bring this drifting thread full-circle, I bought my rolls of Seal-A-Meal bags specifically to vacuum bag 6' foam wing cores when wrapping them in carbon fiber. Of course, they are going on my race car and not a plane, but I had the cores cut by a model airplane CNC place and followed the directions from an R/C web site to wrap them.
Amazing how stuff from one hobby transfers to another one.....
vreihen
