Any thoughts?
Don
GPW wrote:Just a consideration ... You might want to wrap that fglas insulation (like a plastic bag ) , so no particles get shaken out on the road... Easy to just fill some plastic contractor bags with fiberglass, or even cellulose , fold and tape and stuff in the openings and screw a cover over that ...the plastic bag also keeps the fiberglass dry , very important to it's insulating qualities... that's the way we used to do custom vans , some time ago... we even used to wrap the trim cover with matching carpet so the screws wouldn't show.. a bit excessive , I must admit...
d30gaijin wrote:Great idea to encapsulate it in plastic!
vreihen wrote:May I throw out a suggestion and suggest that you look at a roll of Seal-a-Meal "bags" in lieu of contractor bags and tape? The one that I have in my hand right now is essentially a plastic bag material tube that's 11" wide (flattened) and 18' long. All you need to do is seal the ends with double-faced tape or caulk after you stuff it with the itchy stuff, and all should be good (assuming that it fits in the space you're trying to fill).....
Arne wrote:but, it probably does make great airplanes.... most small electrics are foam... I still fly the old fashioned way... with fuel and oil covered planes.
