Are there any cargo conversions
Postby Delphic Oracle » Mon Jul 30, 2012 1:30 pm
that would be under or near 1000 lbs ? Would a tandem axle allow me to pull more weight?
My TV is a 4 cyl. 1.6L Sentra.
Thanks to all for your help.
"Most of the things people worry about will never happen".
Delphic Oracle
Re: Are there any cargo conversions
Postby OverTheTopCargoTrailer » Mon Jul 30, 2012 4:23 pm
They have some 4 x 6 trailers at Harbor Freight $198 you could make into a mini tear drop & that would work.....
However I say for $28k you can get a new 2012 4X4 Tundra limited Crewmax
and that will take you everywhere and back :lol:
http://overthetopcargotrailer.blogspot.com/
Postby Delphic Oracle » Mon Jul 30, 2012 4:45 pm
OverTheTopCargoTrailer wrote:They have some 4 x 6 trailers at Harbor Freight $198 you could make into a mini tear drop & that would work.....
Your humour escapes me. :? I hope that's not your line of work? :roll:
Delphic Oracle
Postby pmowers » Tue Jul 31, 2012 9:02 am
I do not think that you could go any bigger than a 5x8, maybe something the size of the smaller U-Haul trailer. I think that my Lark 6x10 has a curb weight of about 900 lbs, empty.
I think that someone had a thread about a small trailer made out of polyethylene that was really light, I seem to remember that the the manufacturer is in Atlanta, GA.
If you are into rolling your own, I would check out the plans for the foamies, and some of the other really light builds. Good Luck!
Pat
Growing old is mandatory, growing up is optional.
Build log:http://www.tnttt.com/viewtopic.php?f=42&t=51193
pmowers
Images: 43
Postby pappaw » Tue Jul 31, 2012 9:53 am
with a 4cyl, I don't see how an extra axle with help, it may just add more weight than help. :thinking:
I built a 5 x 10 extra height trailer. Check my build out. ;)
I would suggest 4 or 5 foot wide and 8 foot length in your case, and then keep it as simple (light) as possible inside. :thumbsup:
I have found that a V nose will help with the 4cyl. with pulling. :baby:
Be sure to check your owners manual for your cars weight, and towing/cargo limits. :vroom:
Cheers :beer:
Image Cheers from Granny, Pappaw, and Cocoa (the Dachshund) Image
pappaw
Images: 14
Postby GuitarPhotog » Tue Jul 31, 2012 12:04 pm
Have you checked the manufacturer's spec for maximum towing capacity? That will give you a good idea of what you can pull with that small car.
Be wary of small vehicles with high towing capacity ratings, often while the chassis and suspension is adequate the cooling system isn't and either the transmission or engine will overheat under high-load conditions (long uphill grades in hot weather).
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby OverTheTopCargoTrailer » Fri Aug 03, 2012 3:26 pm
Delphic Oracle
NO its YOU that amazes me ..... Its wind resistance that matters most...weight is secondary
well you will see when your 1.6 gets too hot :D :D
I would bet that your car does not even allow towing ??
The lower you keep it, the better
as an Oracle ...you should be able to see that :shock:
Postby Delphic Oracle » Fri Aug 03, 2012 4:41 pm
OverTheTopCargoTrailer wrote:Delphic Oracle
With your superior knowledge why would you be 'amazed' by an ignorant neophyte? :thinkingt:
Would a valium help? :R
Now, do be careful with your syntax...and never try to gainsay an 'oracle'. :twisted:
To all the rest, thank you. I'm learning...despite the obstacles. :lol:
Delphic Oracle
Postby OverTheTopCargoTrailer » Sat Aug 04, 2012 8:10 pm
Hear me now, believe me latter :twisted: :twisted:
I will be standing by for your pictures :thumbsup: :thumbsup:
Oh famous of all knowing Oracle :R :R and master gambler
Postby Deryk the Pirate » Sun Aug 05, 2012 12:51 am
These are about the lightest utility trailers I have seen. I saw 1 in person and it seemed pretty solid.
http://www.bestbuydealer.com/YUPPIE/YUPPIE%20WAGON%204%20FT%20WIDE%20MODELS.htm
Best of Luck!
deryk
Deryk the Pirate
Images: 158
Postby bigbendhiker » Sun Aug 05, 2012 8:30 am
Your original post didn't state what your plans / goals are for your cargo conversion, but you will be limited by what you can safely tow. If you are creative with your conversion and you don't need to camp more than one or two people at the most you could probably make something like this work http://www.haulmark.com/userfiles/HM_PPT4_spec%281%29.pdf. The V-nose gives you 7' of interior length and the empty weight is only 660 lbs. That would allow you several hundred pounds of conversion materials and still keep you under 1,000 lbs which is probably the most you could pull with your Sentra. The V-nose might also help with the towing. As previous posts stated you should also look into additional cooling for your engine, oil, and transmission.
If you do some additional searching you may be able to find a 4'x8' that would work. I doubt you could go much larger than a 4'x8' though. Good luck and let us know what you decide. :)
Scott
bigbendhiker
Images: 28
Postby Delphic Oracle » Sun Aug 05, 2012 9:01 am
bigbendhiker wrote:Your original post didn't state what your plans / goals are for your cargo conversion, but you will be limited by what you can safely tow. If you are creative with your conversion and you don't need to camp more than one or two people at the most you could probably make something like this work http://www.haulmark.com/userfiles/HM_PPT4_spec%281%29.pdf. The V-nose gives you 7' of interior length and the empty weight is only 660 lbs. That would allow you several hundred pounds of conversion materials and still keep you under 1,000 lbs which is probably the most you could pull with your Sentra. The V-nose might also help with the towing. As previous posts stated you should also look into additional cooling for your engine, oil, and transmission.
Notwithstanding all the 'good advice', I am seventy-five, and have neither the energy or skills required to build anything. :oops: I thought this was conveyed in previous posts? :o I posted on the 'conversion' forum to see if there was anything available [to purchase] that could be pulled with my Sentra. My daughter's reaction to all this may be summed up thusly; 'your gypsy days are over....settle down'. :cry:
Perhaps she's right? :thinking: Thanks to all.
Delphic Oracle
Postby OverTheTopCargoTrailer » Sun Aug 05, 2012 9:05 am
I dont understand why you guys are egging him on with that small 1.6 ltr Sentra ,
THE GREAT Oracle
thinks I'm stupid for telling him to get a $199 Harbor freight trailer or to get a decent tow vehicle
96392
96393
Sure these things are really nice but by the time your done you got a supper Ice chest :lol: :lol: for a Honda Goldwing @ $3k
For that kind of money you can upgrade to a PU & camper shell
Postby 8ball_99 » Tue Aug 07, 2012 3:33 pm
Honestly your tow vehicle is just to small to pull a cargo trailer period.. A teardrop trailer would be your only option and even then thats a VERY small motor to be pulling even one of those.. The weight adds up pretty quick and you what a little room to be safe.. As in even if your Tow vehicle is rated for 1000lb you don't want a trailer that heavy.. At most you would be looking for something around 800lb loaded and something that wasnt much taller or wider then the car.
There isn't many companies that make cargo trailer campers. Most on here build their own from cargo trailers. I would also venture to say that probably 98% of the trailers on here are above 1500 loaded.
8ball_99
Postby roadinspector » Tue Aug 07, 2012 11:06 pm
Another option for you is to look at is camper trailers for motorcycles. There are several out there with different options up to and including AC. Most are a popup tent style. Some are small but some are also quite roomy that sleep 2 easily. Hope you find what will fit your needs and functional enough for you. Good luck. :thumbsup:
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Users browsing this forum: Bing [Bot] and 1 guest
