Insulating and condensation?
Postby station29 » Sat Feb 14, 2015 12:21 pm
I have a 36' all aluminum trailer that I'm converting to a toy hauler and it's going to have a propane heater and two rooftop AC units. I want to make sure when using the heater and AC that I don't have a condensation problem. With everything being metal, do I use wood 1x2 and screw them into the existing metal with self tapping screws or do I glue the 1x2 to the metal framing? The entire trailer will have wood paneling on the walls and the ceiling will have wood 4x8 sheets. Any suggestions would be appreciated. Thanks!
station29
Re: Insulating and condensation?
Postby station29 » Sat Feb 14, 2015 12:25 pm
Btw, everything will be vented. As long as it's insulated and vented do I need to worry about condensation?
station29
Postby Mike S » Thu Feb 19, 2015 10:28 am
Yes, condensation will definitely be an an issue. Bases on what you've described, you have haven't provided for any real insulation between exterior skin and the wood, nor do you have a vapor barrier between the interior which is prone to moisture and the metal skin.
Most on this forum have installed a layer of insulation between the wood walls and the metal skin. Some use sheets of rigid foam. Other have had insulation sprayed in.
You can create a vapor barrier in various ways. I used aluminum HVAC tape on the seams of my rigid insulation.
As for your question of how to secure the wood to the skin...I used screws but I'm sure there are many ways to do it.
Good luck!
2013 7 x 16 Charmac Stealth CT , deep in conversion process :)
http://www.tnttt.com/viewtopic.php?f=42&t=66412
2011 Toyota Tundra, 4x4, Double Cab, 5.7L
Mike S
Images: 54
Postby Rainier70 » Thu Feb 19, 2015 10:32 am
What kind of propane heater? Is it vented? If not then, yes, you will have condensation. Propane gives off water when it is burned. Buddy heaters etc produce a ton of moisture that has to be vented out.
Rainier70
Images: 244
Users browsing this forum: Google [Bot] and 5 guests
