Cammo netting for sun/heat reflection
Postby outsidezion » Mon May 25, 2015 10:25 am
PA Wilds Bug out Trailer 16 x 7 x 7 Aluminum: http://www.tnttt.com/viewtopic.php?f=42&t=61833
outsidezion
Re: Cammo netting for sun/heat reflection
Postby Treeview » Mon May 25, 2015 4:14 pm
Dark color=heat absorption
If you wanted a cover it seems like a silver/metalicized tarp would be more effective.
Treeview
Images: 30
Postby norcal2 » Wed May 27, 2015 4:36 pm
I use Aluminet, its durable and works good there are many places that you can order....here is one..
http://www.greenhousemegastore.com/prod ... de-cloth_1
norcal2
Postby Rainier70 » Wed May 27, 2015 4:52 pm
As long as there is space and air flow between the tarp and your camper it should cast shade that will help with the heat.
Rainier70
Images: 244
Postby troubleScottie » Wed May 27, 2015 5:55 pm
Not sure it this will fit the bill.
Although a bit pricey, these are very effective, metal mesh tarp. Good for cooling : reflective and still allowing air flow. We use them for our dogs. They make them in different size. A vendor is listed below. They will make to fit.
http://www.silvershademesh.com/
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 16
Postby outsidezion » Thu May 28, 2015 1:28 pm
I'm thinking more along the lines of the cheap/cool bugout factor. And, if the wind blows it away or it comes apart, no big deal. This is what our military uses in the sandbox - I would think just breaking up the direct line of the sun would make a substantial difference. In desert survival scenarios, a tarp over a tarp with an air gap creates a much cooler environment.
outsidezion
Postby warnmar10 » Thu May 28, 2015 11:22 pm
Rainier70 wrote:As long as there is space and air flow between the tarp and your camper it should cast shade that will help with the heat.
+1
"When a true genius appears in the world, you may know him by this sign, that the dunces are all in confederacy against him." - Jonathan Swift
warnmar10
