Wall Vent
Wall Vent
Postby guardcompany » Mon Oct 19, 2015 6:32 pm
Hello all,
I have a fantastic fan in the roof and really quickly I learned I needed an input air vent so I don't create negative pressure. I bought two of these: http://www.amazon.com/Cycle-Truck-Cargo-Trailer-Vents/dp/B006R5LND0 Anyone have any experience with pros and cons on placement? I have a 6x12. Thanks!
guardcompany
Re: Wall Vent
Postby Padilen » Mon Oct 19, 2015 6:59 pm
My 7x12 came with 2 of them. But it's considered a side by side hauler not CT. So I think they were for gas fumes.
One is on left side high. One is right side low. I'm going to use the left one for holding tank vent. So that will only leave me the lower one. I live on a dirt road and travel dirt roads so for the remaining vent I'm going to add a pieces of furnace filter and try to make a cover for opening and closing the vent. Oh and to keep out our state bird too. Mosquitoes
Padilen
Re: Wall Vent
Postby guardcompany » Mon Oct 19, 2015 8:43 pm
Padilen wrote:My 7x12 came with 2 of them. But it's considered a side by side hauler not CT. So I think they were for gas fumes.
Thanks! Do yours face down or is the vent towards the front of the trailer. I have seen both.
guardcompany
Re: Wall Vent
Postby Padilen » Mon Oct 19, 2015 9:42 pm
The vents both face the rear of the trailer.
Padilen
Re: Wall Vent
Postby OverTheTopCargoTrailer » Mon Oct 19, 2015 9:51 pm
These are the cats meow. ....they open in both directions.....worth every penny.
http://m.ebay.com/itm/181821659382
Re: Wall Vent
Postby Alpha One Nine » Mon Oct 19, 2015 10:03 pm
My trailer came with two of them (3" round hole I think) and, even on low, my Fantastic vent still sucks the side door closed if it's cracked open an inch or two. (I have no windows)
You can really hear the fan working when all of the doors are closed. The trailer is a 6x10 and think I would need at least 4 more to get the air moving properly.
I'm looking for a larger vent solution and would like to keep is as low as possible in one of the rear doors.
I suppose the best solution would be to have an equal opening area for both intake and exhaust. Kind of like building computer for gaming.
Last edited by Alpha One Nine on Mon Oct 19, 2015 10:15 pm, edited 2 times in total.
Alpha One Nine
Re: Wall Vent
Postby Alpha One Nine » Mon Oct 19, 2015 10:05 pm
OverTheTopCargoTrailer wrote:These are the cats meow. ....they open in both directions.....worth every penny.
I bought something just like that but in plastic and have not figured out a way to put a screen in it to keep the tiny flies out.
The little flies here would go right through the gap between the lever and the big mesh.
Maybe some kind of weatherstrip stuff would keep a snug seal yet allow for adjustment.
Alpha One Nine
Re: Wall Vent
Postby guardcompany » Tue Oct 20, 2015 11:47 am
Thank you everyone. Sounds like I am going to want to install another vent besides just the 3'' ones. Maybe one 3'' and one of the larger ones.
guardcompany
Re: Wall Vent
Postby wtcreaux » Tue Oct 20, 2015 11:04 pm
Another option is 2 roof vents.
130628130627
wtcreaux
Images: 211
Re: Wall Vent
Postby Woodbutcher » Wed Oct 21, 2015 7:38 am
Any reason you don't want to add windows. They provide light and a screened window for air flow. You will never get good air flow from those small vents.
Woodbutcher
Re: Wall Vent
Postby guardcompany » Wed Oct 21, 2015 1:05 pm
Woodbutcher wrote:Any reason you don't want to add windows. They provide light and a screened window for air flow. You will never get good air flow from those small vents.
I have a window in the door. (http://easyrvwindows.com/rv-entry-door.html) I'm thinking of having a screen made for it and just call it a day there.
guardcompany
Re: Wall Vent
Postby McDave » Wed Oct 21, 2015 6:33 pm
Bingo!
I have also wondered about floor vents, seems like the coolest air available may be under the CT in the shade?
McDave
Images: 412
Users browsing this forum: Google [Bot] and 2 guests
