Waterpump
Waterpump
Postby mrwall1 » Mon Feb 27, 2017 10:20 pm
Well I am getting ready to order a few items to start my build.... Hopefully ill get a lot of opinions! what 12volt water pump should I get.... I see a shur-flow on amazon for $70 plus... and a sea-flow for $30 plus..... I don't think well need a lot of pressure... RV toilet... and a Kitchen sink... and an outdoor shower... not planning on using the shower a lot...
mike
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Re: Waterpump
Postby Socal Tom » Tue Feb 28, 2017 8:21 am
That one should work, but I can't say how long it will last with a small motor.
Sent from my Lenovo A7600-F using Tapatalk
Socal Tom
Re: Waterpump
Postby Aguyfromohio » Tue Feb 28, 2017 8:43 am
There are two ways to move water. One is directly with a water pump.
The other is "air over water" with an air pump.
The water tank has an air space above the water surface, and a little air pump, controlled by a pressure switch, put a few psi over it to push water out the faucet.
When I was a kid my dad had little travel trailers with each.
The direct water pump was noisy and surged. The air over water system was quiet and smooth.
Aguyfromohio
Images: 76
Re: Waterpump
Postby McDave » Tue Feb 28, 2017 10:51 am
Hey Mike,
Check out Ebay. I was able to get tank, pump and accumulator as a combo. All different sizes and shapes. Think about where you plan to mount tank, volume and weight distribution. Closer to the axle (over or under) affects the tongue weight less, empty or full.
McDave
McDave
Images: 412
Re: Waterpump
Postby Socal Tom » Tue Feb 28, 2017 12:07 pm
I recommend the accumulator. In a little trailer like this you need something to give the system some volume. Really helped a lot with mine.
Socal Tom
Re: Waterpump
Postby flboy » Tue Feb 28, 2017 12:24 pm
Ditto on the accumulator. They make a noticeable difference especially when you are trying to "trickle" water . The pump will work without it if the extra cost is a factor.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: Waterpump
Postby flboy » Tue Feb 28, 2017 12:26 pm
Btw... Sureflow seems to work well for me. No experience with the other brand.
Don (Flboy)
flboy
Images: 378
Re: Waterpump
Postby mrwall1 » Tue Feb 28, 2017 8:02 pm
flboy wrote:Btw... Sureflow seems to work well for me. No experience with the other brand.
Thanks guys for your help, I ended up ordering the shur flow revolution... "it says" that it will trickle water... I assume that meant without an accumulator... but I have one in my cart on amazon ready to order just incase!
after scrolling through Don's build I think I finally found it on page 45 or something!! LOL!!!
I Will start my build thread Later tonight... started tearing into it a little today.... oh crap the workmanship!!!
Mike
mrwall1
Re: Waterpump
Postby McDave » Wed Mar 01, 2017 4:01 pm
mrwall1 wrote:.... oh crap the workmanship!!!
... :o
Yup. We've all said that before.
Welcome to the madness.
McDave
McDave
Images: 412
