found old lantern Quick lite year?
Postby mvperini » Sun Jan 16, 2011 8:27 pm
Found a coleman quicklite lantern today would like to find out what year it was made. no date made in kansas nickle bottom with a brass top looks like original globe
Mike
1947 Kenskill teardrop kamper 4X10>
1951 Boles Areo 16ft Canned Ham>
1956 Roadmaster 20ft> Restored
1959 airstream 18ft restoration complete
1953 Pontiac house car
mvperini
Postby doug hodder » Sun Jan 16, 2011 8:33 pm
Maybe 1925-27...does it have a looped generator? Doug
lantern
Postby mvperini » Sun Jan 16, 2011 8:36 pm
Doug it does have a looped generator
Mike
mvperini
Postby doug hodder » Sun Jan 16, 2011 8:41 pm
I'd bet 1927, looks like this one, scroll down 1/2 way. Doug
http://terrence.marsh.faculty.noctrl.ed ... tpre31.htm
lantern
Postby mvperini » Sun Jan 16, 2011 8:45 pm
Thanks Doug, now to clean it up and get it working
Mike
mvperini
Postby doug hodder » Sun Jan 16, 2011 8:47 pm
While I don't have one with a Q99 generator, I believe that you need to preheat it prior to lighting. Doug
Postby parnold » Sun Jan 16, 2011 9:47 pm
Yeah you need to preheat the generator. In the old days they said to use two wooden matches to preheat it. They are a little tricky to light. Somewhere I found pdf directions and I can email them to you if you want. I have no idea where I found them so I can't link you.
parnold
Images: 302
Postby PresTx82 » Mon Jan 17, 2011 7:18 pm
Nice one. Hope you got a good deal.
Mark
El Paso, Texas
PresTx82
Postby Rock » Mon Jan 17, 2011 8:11 pm
Nice - especially the mica globe. I've got a March 27. Looks like yours has an air inlet on the fill cap as if it used a separate pump. Somebody probably replaced it down the line.
The looped Q99 generator is no longer available new (I think) and most replace them with a R55 roto-generator that is still available new. The R55 is straight with a built in cleaning tip. The Q99 can't really be cleaned so if it's plugged it's pretty much shot.
Eric
Rock
Images: 48
Postby teardrop_focus » Wed Jan 19, 2011 10:18 am
Mike!
That's a cool acquisition... :thumbsup:
You might want to check this thread over on the CCF before you try to light yours. It talks about fireballs and the distinct need to pre-heat the generator before lighting...
http://oldtownyucca.websitetoolbox.com/post?id=5054928
teardrop_focus
Images: 127
Postby parnold » Wed Jan 19, 2011 10:36 am
You can still buy Q99 generators off Ebay, but they go in the 20 - 30 dollar range for NOS (new old stock). I have a bunch of em that I have cleaned up, and one NOS that I'm saving. I have 5 of the old quick light lanterns that use those generators. I've only tried firing one up, and never got it to burn quite right.
parnold
Images: 302
Postby Mark72 » Wed Jan 19, 2011 6:43 pm
I've got one of those. They are really bright just like my house lamps. I preheat the gen. with a micro torch I have. Crack the valve open just after the residual fuel lights off in the mantel. If you do it wrong you will know it! I recommend a few practice runs outside if your not used to these lanterns! :shock:
Mark
Mark72
Images: 127
