slowcowboy wrote:whats the contest. I am plumb late old slow has been slow to get on here as normal.
does it have to be a 2 burner suit case one?
slow
Zollinger wrote:slowcowboy wrote:whats the contest. I am plumb late old slow has been slow to get on here as normal.
slow
Yup you just need a standard whitegas 2 burner stove, some paint, and your imagination. Stove MUST work, and close up. Decorate it anyway you want. Take a couple of pics of it and pics of it working. We have until December 31st I think to get it done.
doug hodder wrote:The boxes on stoves don't get that hot unless you put too large of a pan on it and force the heat out into the box sides. 425's are notorious for this, 413's to a lesser extent. Watch big skillets! All of them will scorch if you're not paying attention and get carried away. I've measured mine and they only get up to about 140F. Regular old rattle can paints can handle that. The high temp paints will be flat, or the lesser high temp ones (ie, engine block and brake caliper) will have limited colors available. I do use VHT paint on the burners manifold and generator however. Make sure you have the box really degreased, clean and prepped for best paint adhesion. Doug
