How about a winter "Coleman stove"contest?
Re: How about a winter "Coleman stove"contest?
Postby bonnie » Sat Oct 06, 2012 5:34 am
Thanks for doing this. I am excited to get my stove done. :)
Remember, the turtle won. :)
bonnie
Images: 107
Postby Zollinger » Sat Oct 06, 2012 9:49 am
slowcowboy wrote:whats the contest. I am plumb late old slow has been slow to get on here as normal.
does it have to be a 2 burner suit case one?
slow
Yup you just need a standard whitegas 2 burner stove, some paint, and your imagination. Stove MUST work, and close up. Decorate it anyway you want. Take a couple of pics of it and pics of it working. We have until December 31st I think to get it done.
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Postby wagondude » Sat Oct 06, 2012 11:10 am
slow
Actually December 23. That gives me the week after Christmas to get the poll set up for voting. I edited my sig with the link to the rules so folks can find it for easy review.
Bill
101137
wagondude
Images: 35
Postby Wolffarmer » Sat Oct 06, 2012 6:15 pm
I hope that is Dec 23 2013
:oops:
Randy
Wolffarmer
Images: 309
Postby wagondude » Sun Oct 07, 2012 6:55 pm
Well, Randy, If you need that long, maybe we could get another contest going next year. But let's see how this one goes first. :D
Bill
101137
wagondude
Images: 35
Postby wagondude » Thu Oct 18, 2012 4:16 pm
Has anyone started on a stove yet? Inquiring minds and all that.
Bill
101137
wagondude
Images: 35
Postby campmaster-k » Thu Oct 18, 2012 5:02 pm
Very soon.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby logman7777 » Thu Oct 18, 2012 5:07 pm
Im still looking for a White Gas 2 Burner before I get all Profane.. :D
Would love to do the 3 burner but that would be an unfair advantage when it comes time to cook..LOL
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Postby campmaster-k » Thu Oct 18, 2012 5:11 pm
Three burners are cool but take up lots of space. One is a must.
-Kirk
Build thread -
campmaster-k
Postby logman7777 » Thu Oct 18, 2012 6:31 pm
Yup Yup that 3 burner is rather large but perfect for doing my Ribs when camping.
logman7777
Postby TRP » Thu Oct 18, 2012 8:18 pm
I picked up a stove, but now I've realized I've never rebuilt a stove before. Do they require special heat resistant paint? or can I use any ole rattle can paint?
Ted
TRP
Images: 341
Postby logman7777 » Fri Oct 19, 2012 6:30 am
Im going to be using automotive engine paint for the body and high temp on the burners but maybe the pros will chime in on this since this will be the 1st stove I refinish too..
logman7777
Postby doug hodder » Fri Oct 19, 2012 4:07 pm
The boxes on stoves don't get that hot unless you put too large of a pan on it and force the heat out into the box sides. 425's are notorious for this, 413's to a lesser extent. Watch big skillets! All of them will scorch if you're not paying attention and get carried away. I've measured mine and they only get up to about 140F. Regular old rattle can paints can handle that. The high temp paints will be flat, or the lesser high temp ones (ie, engine block and brake caliper) will have limited colors available. I do use VHT paint on the burners manifold and generator however. Make sure you have the box really degreased, clean and prepped for best paint adhesion. Doug
Postby logman7777 » Fri Oct 19, 2012 5:04 pm
doug hodder wrote:The boxes on stoves don't get that hot unless you put too large of a pan on it and force the heat out into the box sides. 425's are notorious for this, 413's to a lesser extent. Watch big skillets! All of them will scorch if you're not paying attention and get carried away. I've measured mine and they only get up to about 140F. Regular old rattle can paints can handle that. The high temp paints will be flat, or the lesser high temp ones (ie, engine block and brake caliper) will have limited colors available. I do use VHT paint on the burners manifold and generator however. Make sure you have the box really degreased, clean and prepped for best paint adhesion. Doug
Thanks for the info Doug! I was always wondering how hot it got with normal cookware. I know when I do a rectangle pan for my ribs the body and sides get really hot since the pan is the same size as the burner grate on my 2 burner. I learned the hard way cause even with the feet extended it scorched a picinic table (whats that burning smell? :thinking: ) so now it goes on a Coleman stove stand.
logman7777
Postby Woodbutcher » Sun Oct 21, 2012 5:42 pm
I have mine torn apart and my paint bought. My theme is set so now all I have to do is get going! This will be fun, I hope more join in.
Woodbutcher
