Rebuild parts
Rebuild parts
Postby suckerpunched » Mon Nov 15, 2010 7:54 pm
I've got a 1953 Coleman red lantern that won't hold pressure. Is there a source for rebuild parts and pieces?????
Thanks,,,TC :thinking:
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby Ageless » Mon Nov 15, 2010 8:56 pm
Ageless
Postby parnold » Mon Nov 15, 2010 9:54 pm
also check ebay for parts once you're sure of the part numbers.
parnold
Images: 302
Postby Wolffarmer » Tue Nov 16, 2010 1:42 am
If it won't hold pressure, the fuel cap gasket is probably shot. That is the most likely problem but not the only one. There are many sellers on Ebay of the cap gaskets. I just saw a new one tonight with some very good prices. Have no idea of the quality.
http://cgi.ebay.com/10-large-filler-cap-seal-gaskets-fit-Coleman-lantern-/110609520517?pt=LH_DefaultDomain_0&hash=item19c0d75785
Yours is probably a large cap and those will work. On ebay search "coleman gaskets". The older ones 40's something and earlier have smaller ones. I have seen 3 different types of gaskets in my little collection and experience. One of my lanterns from 1927 I have an O ring in it. It works but the cap doesn't screw all the way down.
Randy
Randy
Wolffarmer
Images: 309
Postby doug hodder » Tue Nov 16, 2010 10:16 am
Randy...some of the really old ones had a lead gasket/washer in them, my Quiklite has one. Once it gets marked up and doesn't seal...heat them and get the lead to flow again and it will smooth itself out. I'd bet that was what your '27 had in it. Doug
Postby suckerpunched » Wed Nov 17, 2010 6:17 pm
Thanks for the help,,,I'll try a new gasket in the cap
TC
suckerpunched
Images: 22
Postby suckerpunched » Fri Nov 19, 2010 8:07 pm
I burned and scraped out the old gasket in the fuel cap and after some fresh fuel and a few tries,,,, she works
Thanks all,,,,TC
suckerpunched
Images: 22
