Todays $10 find 413G and a 1990 285 lantern
Postby kzhorse » Sun Nov 20, 2011 3:00 pm
Not sure what to do with this yet pretty rustyand was full of mouse nest and fuel cap is rusted on.
Not sure of the year (dont know where to look on a stove) so I may just blast the whole thing down to bare metal and repaint.
The bail nut was rusted but the mantles were intact and it held presure so I used itself to put heat and lube to break the nut loose.
And the bonus there was 3 packs of mantles in the box.
Scott
kzhorse
Postby kzhorse » Sun Nov 20, 2011 3:32 pm
Well looks like the 413G is a loss the mouse nest has taken a toll on the bottom.to many holes to make it worth the time.
The burner and tank should clean up so we shall see. :(
Scott
kzhorse
Postby Joamon » Sun Nov 20, 2011 8:35 pm
You may be able to put a false bottom in the stove to make it usable. Also if you turn the tank over sometimes there is a date stamped on the underside of the tabs. Where did you come up with these? $$$$
Looks like a project.
Keith
Joamon
Images: 244
Postby kzhorse » Sun Nov 20, 2011 8:49 pm
Joamon wrote:You may be able to put a false bottom in the stove to make it usable. Also if you turn the tank over sometimes there is a date stamped on the underside of the tabs. Where did you come up with these? $$$$
Keith
I put a request on craigs list looking for a 2 burner stove.
Scott
kzhorse
Postby campmaster-k » Sun Nov 20, 2011 9:05 pm
kzhorse wrote:Well looks like the 413G is a loss the mouse nest has taken a toll on the bottom.to many holes to make it worth the time.
Scott
Scott - Dont chuck the stove. Even if you think it to be a basket case just keep it for parts. :thumbsup:
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby kzhorse » Mon Nov 21, 2011 8:18 am
I am taking nthe burner and tank to work to media blast and see if I can get the cap off and check for leaks, I'm keeping the lid and burner grate the rest is not worth my time.
Scott
kzhorse
Postby Kevin & Sandy » Tue Nov 22, 2011 12:20 pm
Hey, I have an idea for the lid of an old Coleman stove. I was taking apart a 426 so I could clean it all up and paint it, and it occurred to me that the lid and the side shields might work perfect for wind protection for a Dutch Oven on a windy day ! I have not tried this because I do not have an unrestorable stove yet, but wouldn't that work?
It would be light and already hinged, and serving almost the same purpose it was designed for !
Anyone done this?
Kevin & Sandy
Images: 46
Postby doug hodder » Tue Nov 22, 2011 12:38 pm
On that 413G...you might have a valve. The tank is probably not usable based on the rest of it. I'd bet it's full of rust. They are so plentiful, it's not worth messing with. Doug
Postby kzhorse » Wed Nov 23, 2011 12:14 am
The tank and burner cleaned up pretty good,The tank still had some fuel and still holds pressure.I may just say screw it and clean the rest and just use it as is.I'll take some pictures in the morning after I fire it up.
Scott
kzhorse
Postby kzhorse » Thu Nov 24, 2011 4:01 pm
Well here is the stove now,It works good I might have to clean the box and use it.
Just ignore the knob I used the original on a lantern that I am making look old skool.
:twisted:
Scott
kzhorse
Postby DragonFire » Thu Nov 24, 2011 4:47 pm
Lookin' good...may be a keeper after all!!
I have been working on my lantern today...still can't get it apart, but used some rubbing compound on the paint. My lantern may just match your stove...usable but not pretty. Hey, if it's too pretty some fool will walk off with it while you are camping anyway!!
Good luck on cleaning up the rest of the stove!
'79 Grasshopper
Coleman Keepers 200a Gang
DragonFire
Images: 21
Postby Joamon » Thu Nov 24, 2011 4:48 pm
I have two that I would like to redo. Right now they burn alot of orange flame. What would be the cause of this. What should be my first couse of action.
Your tank looks good and burn clean! :thumbsup: :applause:
Keith
Joamon
Images: 244
Postby kzhorse » Thu Nov 24, 2011 5:26 pm
Joamon wrote:I have two that I would like to redo. Right now they burn alot of orange flame. What would be the cause of this. What should be my first couse of action.
Keith
Does it always burn orange? even after it warms up?My guess would be a cloged generator try running some carb cleaner or Seafoam in with the gas or take it apart and give it a good soaking.One other thing it may have a spider web/nest in the bunson.
Scott
kzhorse
Postby kzhorse » Thu Nov 24, 2011 5:37 pm
Here is the 285-700 I just didnt like the look of the silver.
Not the best picture will take some tommorrow(No flash on my phone)
I should have a green vent for it tommorrow when the mail shows up.
Now I need a generator, it never ends.
Scott
kzhorse
Postby DragonFire » Thu Nov 24, 2011 7:09 pm
I like the red on the lantern!!! What paint did you use? It looks really good!
I think this hobby is one where you are never done. Always something. But would it be fun if it was easy? Or if you could buy pristine pieces for your collection? No. That's why I'm struggling with my lantern. I wanted a fixer, and I got it! :D
'79 Grasshopper
DragonFire
Images: 21
