by Lazybones » Mon Jan 16, 2012 11:21 pm
I find that most of the time they leak at the packing nut behind the on off knob or tip cleaner lever. Try to tighten them first.
When you pump it up the first time prelighting. only put in 15-20 pumps. Open valve 1/4 turn and light it. After the mantel lights and becomes steady. Pump it 15-25 more times and open the valve all the way.
Lee
Is it true? Is it necessary? Is it kind? Ask yourself these simple questions every time you are in doubt about any action.
