rainjer wrote:I made this one. I used some 1/8" X 3/4" aluminium stock, part a a solar tub, a piece of dowel & some pop rivets.
Jeremy
dratkinson wrote:Thought I saw a lantern with a reflector on here a while back that looked to be homemade. It appeared to be made out of sturdy aluminum. It was a half cylinder with an open bottom and a hole and two short slots cut into the top. The hole allowed the reflector to be mounted using the lantern's top thumb nut. The two short slots allowed clearance so the lantern's wire handle could come straight up for hanging the lantern.
I thought, if I had to, I could make one like it from a 2lb coffee can. That can size is a little small to fit over a small hat lantern, but figured I could split the sides a little from the bottom (top of the reflector) and offset the mounting hole to make it work.
Feel free to use this idea as you see fit. If you make a coffee can reflector, let us know how it works. Show us some pictures.
(Added) Thinking about it a little more, that aluminum half cylinder I saw made into a reflector could have been a cut-up aluminum pot. Could probably find a suitable cheap one at a Goodwill/thrift store.
