Cybotics 5ft by 12ft 2014 build
Postby Cybotics » Wed Mar 19, 2014 12:50 pm
This is Cybotics (Nick's) Build Journal. I am a newbie to Building teardrops but I have built plenty of things in the past few years like, robots that won state championships in high school.
Lets Get started on this journey that I am about to embark on.
Details: What I know I want to have and how I want it to look.
118036
    Real Stainless sink
    Built in stove with oven
    Coleman plugin cooler (or similar)
    Queen Size Bed
    2- 20lb Propane Tanks (BBQ size)
    2- Deep Cycle Batteries
    180 watt solar kit
    Power converter
    Large water tank (That's the headboard in the pic)
    16 gallon Grey tank (under sink)
    32" LED wall mounted TV with DVD (for the kids)
    some sort of tank monitor (Probably Arduino controlled)
What I have done so far.
118037
I have the 1/2 CDX floor done with 1x2's
118039
I also have the bottom of the floor coated with
118038
It looks pretty Good
I Look forward to Comments and suggestions
Thanks Cybotics (Nick) :D
Cybotics
Images: 7
Re: Cybotics 5ft by 12ft 2014 build
Postby Woodpecker » Wed Mar 19, 2014 2:50 pm
Great start!
Are you in FIRST? I'm an old school Battlebots guy that still helps out there. We just finished the San Diego comp. The robots sure get you out in the garage don't they?
Woodpecker
Images: 186
Postby Cybotics » Wed Mar 19, 2014 2:53 pm
I Was in FTC I graduated 4 years ago and haven't done anything with them since :cry:
Cybotics
Images: 7
Postby rowerwet » Wed Mar 19, 2014 3:14 pm
that is quite a bit to bite off for the first build.
the 2 propain tanks seem serious overkill unless you are planning on extended stays on the road/off the grid. (most here use 1 lb bottles for cooking, light, etc. 1 bottle will last a weekend for most)
they also seem they would be creating a heavy tongue weight combined with the water tank. Then as you use the water you end up with the water weight aft of the axle in the galley, not impossible to deal with, but a too heavy tongue turning into a too light tongue can really mess with your packing. Most builders try to keep the fresh and grey tanks as close to the the axle as possible (even right over it) to minimize changes to balance.
What is the plan for the space going across just behind the axle? a room for kid(s)/ closet?
I can't recommend enough having two doors on a tear, unless it will be just one person all the time.
rowerwet
Images: 521
Postby Cybotics » Wed Mar 19, 2014 3:25 pm
rowerwet wrote:that is quite a bit to bite off for the first build.
The reason for having 2 Tanks, 1 for the Big Buddy heater I have it uses lots of propane, also my stove is a stove from an older RV and if I use the oven it also uses lots of propane.
The space in front of the galley will most likely be the Grey water tank and storage for the fold up camp chairs and clothes. Wiring junction and the converter.
I don't have enough room right over the axle for the fresh tank or I would.
Cybotics
Images: 7
Postby Cybotics » Thu Mar 27, 2014 12:59 am
Here is my update I got the passenger wall done then realized I forgot to cut out the door. So I will cut it out then frame it. I also got this propane tank at homedepot for $20 what a steal. [attachment=-1]uploadfromtaptalk1395899838923.jpg[/attachment][attachment=-1]uploadfromtaptalk1395899853669.jpg[/attachment]
Cybotics
Images: 7
