KeeF's lozenge camper
Postby keeflester » Mon Apr 20, 2015 3:45 am
Hi, I'm building a camper for my sister to replace the teardrop she had which had suffered serious water ingress leading to terminal rot. We dismantled it with a chainsaw and saved the Alko chassis for re-use. The new trailer is to be as simple and as light as can be. I have experience of building in plywood on softwood so that's the method I've adopted. The shape is octagonal and very reminiscent of the Victory V lozenge, hence the name, Jackie's lozenge camper. I have put up some early pictures into an album. Can somebody tell me how to get them to display on this thread please. Kind regards, K33F
keeflester
Images: 16
Re: KeeF's lozenge camper
Postby noseoil » Mon Apr 20, 2015 7:41 am
Set up an account online for free with a 3rd party hosting site (I use photobucket for my stuff).
Upload from your computer to the site.
Click on each picture, individually, and you will have a menu at the top of each one. On the left are 5 colored links, on the right there are 4 gray scale links. In my browser, the gray scale one on the left (looks like two chain links) will open a dialog menu. Click on it and a dialog menu opens. The bottom link is the one youe want.
Click on the bottom link and it will automatically copy into your mouse.
Once you have a message going to post in your thread, right-button click in the thread where you want to image and (paste from the menu which opens) it will paste where the cursor is blinking.
There will be a string of text starting with [url=http:.... and ending with .jpg.html]. Get rid of it and just leave the string which starts with Image. You will have to backspace or delete the[/url] out which is at the end of this long string of text.
This is the actual image. While it seems like a virtual PITA, it's pretty easy once you've run through it a few different times.
Best, waiting to see some pictures!
137905
noseoil
Images: 670
Postby 39Ratrod » Mon Apr 20, 2015 7:52 am
Build is looking good. I checked out your photo's and posted one here.
The biggest difference between a dreamer and a doer is the follow through.
39Ratrod
Images: 71
Postby keeflester » Mon Apr 20, 2015 11:38 am
130867
Main structure and framework from 26x33mm softwood on a 12mm marine ply base tub.
keeflester
Images: 16
Postby keeflester » Mon Apr 20, 2015 11:42 am
130872
Detail of pocket hole cabinet construction using Kreg jig and Kreg screws
keeflester
Images: 16
Postby Da'engineer » Thu Apr 23, 2015 7:41 am
You can also post pictures on here if you post your pictures on facebook then copy url
Da'engineer
Postby bobhenry » Tue Apr 28, 2015 6:59 am
Well I have been banging together wood for about 5 decades. I never used a pocket hole jig in my entire 64 years. This weekend I built 11 cabinet door fronts for my 86 year old mother. That's 88 holes and 88 screws to make the picture frames. I then added a bead board panel inside of the frame. I was well pleased with the results. If you are looking for a present for yourself or the craftsman in your life I can very highly recommend this style of tool. I purchased the harbor freight all aluminum pocket hole jig but did purchase the Kreg style pocket screws. This tool in my opinion is the greatest thing since sliced bread.
