Tennessee Teardrop
Tennessee Teardrop
Postby Propstrike » Tue Sep 29, 2015 8:39 pm
This evening marks the beginning of construction of my 5W x 8L x 4.5H teardrop. I've been drafting plans and storing up supplies for weeks, and the time has finally come!
I'll be building in somewhat of a cramped space, but it will be dry and warm.
The wheels/axles have been removed, and the chassis is on buckets.
The attachment ImageUploadedByTapatalk1443577177.668223.jpg is no longer available
Propstrike
Re: Tennessee Teardrop
Postby Propstrike » Tue Sep 29, 2015 8:45 pm
Using a Kreg jig, I cut and joined floor framing that will be sandwiched between two layers of birch ply later.
Propstrike
Postby aggie79 » Wed Sep 30, 2015 8:47 am
Congratulations on your progress! :applause: :thumbsup: :applause:
Keep us updated on the build.
Postby KennethW » Wed Sep 30, 2015 9:04 am
In a tight space after you put the wheels on. The HF square wood moving dolly's work good.
KennethW
Images: 82
Postby Propstrike » Wed Sep 30, 2015 4:20 pm
I'll probably leave the wheels off until I'm finished. I'll certainly take your advice and pick up a couple dollies to move it out the door. I'll put the axle back under it once outside.
Propstrike
Postby Jdw2717 » Thu Oct 01, 2015 9:30 pm
Let us know if you have any questions and keep us posted on you build. We like pictures. :thumbsup:
"Twenty years form now you will be more disappointed by the things that you didn't do than by the ones you did. So throw off the bowlines... Explore. Dream. Discover" Mark Twain
John & Tatanya
Jdw2717
Images: 34
Postby Propstrike » Fri Oct 02, 2015 5:30 pm
Last night was my last bit of work on the TD for a few days. Asphalt coating for underneath went down. Now, just waiting for it to set up and off gas before I resume.
Propstrike
