" The White Elephant" formerly know as "KISS" Skin on
Re: KISS drawings Finally got some time to work on it. Pics
Postby lrrice » Sat Oct 17, 2015 12:02 am
Clamped cross members together so they all keep the same angle.
bows clamped.jpg (133.51 KiB) Viewed 1863 times
Welded them up.
bows welded.jpg (66.72 KiB) Viewed 1863 times
Got the uprights and bows tacked in and scrounged every ratchet strap I could find for x braces to square it all up.
lrrice
Images: 7
Postby lrrice » Sat Nov 21, 2015 11:27 pm
Sorry about the bad pictures still trying to figure out how to resize and send directly from the phone.
2015-11-21 21.21.01.jpg (189.58 KiB) Viewed 1818 times
Outside waiting on wood and foam.
2015-11-21 21.04.23.jpg (230.7 KiB) Viewed 1818 times
Got some wood and insulation on.
lrrice
Images: 7
Re: KISS updated pictures
Postby lrrice » Wed Dec 02, 2015 8:07 pm
Finally getting around to putting up progress pictures.
137859
I wrapped the bottom of each sheet with painted canvas to protect the exposed edge.
137862
After 10 gazillion screws and pop rivets its ready to sand the putty. If i had to do it again I would do it all with counter sunk pop rivets or flat head self drilling screws but I didn't have enough of either so I had to use regular pop rivets which were harder to hide.
lrrice
Images: 7
Postby lrrice » Wed Dec 02, 2015 8:21 pm
Sorry I didn't get pictures of the canvasing process but I barely had enough hands between my son and I to get it done. In short, I didn't pre-shrink and only had issues on the inside corners of the door jambs. I just had to staple down the jamb corners while the paint was wet and it worked great. Other wise it worked perfectly. I used 7 oz canvas I got from Big Duck on sale for 2.99 a yard. It came on a roll with no wrinkles so no washing or ironing. I wrapped from the back door all the way around in one piece. I lapped that several inches up on the roof. Then I covered the roof allowing it to lap down over the wall about 1". The canvass pulled down very tight against the wood, showing every flaw I ignored while sanding, forming a nice tight good looking skin.
I am now dubbing it the "White Elephant" and it is in desperate need of graphics. I still have to build the doors, fenders and running boards. That should break up the monotony a bit, but I am open to simple graphic suggestions from anyone who has the artistic or creative gene that I seem to be missing.
137861
137860
137858
lrrice
Images: 7
Re: " The White Elephant" formerly know as "KISS" Skin on
Postby Vedette » Thu Dec 03, 2015 12:55 am
Circus Wagon Cage with an Elephant in it???
Just a thought??
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby KCStudly » Thu Dec 03, 2015 9:21 am
The easiest graphic of all would be a simple stripe running horizontally just below the mid belt line. You could do two tone with a darker color below and a lighter color above the stripe (tone on tone).
You could add a few jags in the stripe to jazz things up and give a sense of motion, while breaking up the broad panel even more. Something like this:
... but you may want to get your doors, fenders and any rock guarding in place so that you can make sure the graphics complement them.
Postby Vedette » Thu Dec 03, 2015 9:13 pm
As most White Elephant gifts .....just plain white wrapping with a red ribbon and bow. :twisted:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby lrrice » Fri Dec 04, 2015 6:38 pm
I'm thinking maybe a blue ribbon. The circus wagon may be a bit much :) I do like the stripe though. I may make it a combination of blues and white in that general pattern.
lrrice
Images: 7
Postby noseoil » Sat Dec 05, 2015 8:45 am
I'm thinking something a bit retro, more like the front of a P40 (the Flying Tiger). Why not just go for it!
137905
noseoil
Images: 670
Postby Vedette » Sat Dec 05, 2015 5:05 pm
noseoil wrote:I'm thinking something a bit retro, more like the front of a P40 (the Flying Tiger). Why not just go for it!
Don't you think this trailer is closer to a "Box Kite" then a P40?????? :R
With its aerodynamics I would think painting like a "Gas Pump' would be more appropriate........not trying to be mean here!
Just saying??????? :shock:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby lrrice » Tue Dec 08, 2015 1:49 am
All the aerodynamics of a cargo trailer. Most people buy. A cargo trailer and convert it, I'm so cheap I have to build it so I can convert it. In it for about 700 now, cheapest junkers I could find were at least 1500.
lrrice
Images: 7
Postby Vedette » Tue Dec 08, 2015 3:43 pm
:thumbsup: :thumbsup:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
