16 foot single wheel unusual TD build
Re: 16 foot single wheel unusual TD build
Postby 3nero » Tue Jul 01, 2014 6:59 pm
I second a shield for the bag
I've had a few blowouts and have seen the damage they can do.
I once had the rear suspension airbags on a large trailer shredded by a blowout :cry:
Measure once, cut twice....throw away and repeat.
http://www.tnttt.com/viewtopic.php?t=55971
3nero
Postby KCStudly » Tue Jul 01, 2014 9:25 pm
My first thought upon reading the idea about a shield was that, unless it can withstand a blowout itself, it is just as likely to slash the bag as the blowout alone. So if done, should be done stout and mounted very securely.
$.02 worth.
Postby WeirdDogGuy » Wed Jul 02, 2014 7:28 am
3nero wrote:I second a shield for the bag
You talked me into it!
WeirdDogGuy
Postby WeirdDogGuy » Wed Jul 02, 2014 7:38 am
KCStudly wrote:My first thought upon reading the idea about a shield was that, unless it can withstand a blowout itself, it is just as likely to slash the bag as the blowout alone. So if done, should be done stout and mounted very securely.
$.02 worth.
I think it will depend on what the shield is made of; I'm thinking aluminum, maybe 1/8 IN +/-. I think I have some 14 gauge AL that needs to be used up so that's just shy of 1/8IN. If I make a tub or wheel well that encloses the wheel area but excludes the air bag, I think I'd be OK. It would probably deform if the tire blew but I could just hammer it back out.Thx.Andy
WeirdDogGuy
Postby KCStudly » Wed Jul 02, 2014 8:51 am
That makes more sense than what I was envisioning. I had pictured a smaller shield local to the bag; i.e. a can opener if bent, or shrapnel if adrift. A full inner fender is a much better idea. :thumbsup:
Postby WeirdDogGuy » Wed Jul 02, 2014 1:04 pm
I had to move the bottom perch over to the side in order to have better access to the bottom anchor bolt:
Making a cardboard template for the steel side bracket that will support the bottom perch:
WeirdDogGuy
Postby WeirdDogGuy » Thu Jul 03, 2014 8:02 am
Laying out the template patterns so that I only have to drill one hole:
Drilling the hole:
Shaping the brackets. Close enough, ready for welding:
WeirdDogGuy
Postby WeirdDogGuy » Fri Jul 04, 2014 2:16 pm
As this is coming together, I'm realizing how over-designed it is. But that's OK; better too strong than too weak:
WeirdDogGuy
Postby capnTelescope » Fri Jul 04, 2014 4:00 pm
No one's saying much 'cuz you're breaking new ground here. (Smiley of a shovel throwing dirt out of a deep hole) But we're watching. :SG You're doing good. Can't wait for the next episode. :thumbsup:
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby GuitarPhotog » Fri Jul 04, 2014 6:58 pm
Have you done a proof of concept with a single wheel behind a single tow point?
<Chas>
GuitarPhotog
Images: 55
Postby S. Heisley » Fri Jul 04, 2014 7:15 pm
I can't tell much from the pictures so far. I'm waiting to see a "full body" front-to-back chassis picture. Even after I see that, I may not know what to say. For those of us who are bolt-together chassis people, you are way out of our league. We're in the Pee-wee league. :lol:
Postby WeirdDogGuy » Fri Jul 04, 2014 7:48 pm
capnTelescope wrote: But we're watching. :SG
You and the NSA both :)
GuitarPhotog wrote:Have you done a proof of concept with a single wheel behind a single tow point?
<Chas>
No, I have not.
S. Heisley wrote:I can't tell much from the pictures so far. I'm waiting to see a "full body" front-to-back chassis picture. Even after I see that, I may not know what to say. For those of us who are bolt-together chassis people, you are way out of our league. We're in the Pee-wee league. :lol:
I know a lot of what I'm doing now may seem boring but I'm posting it anyway so in the future, people can see how I built and learn from my mistakes or successes. I have to admit, I'm really eager to get on to coach building since that is when it really starts to look like a teardrop
Thanks for the comments.Andy
WeirdDogGuy
Postby dodgedartgt » Fri Jul 04, 2014 9:49 pm
Happy 4th!
Now, you've only got two more build days before Monday... So get on with it already. He he he
Mike in FL
dodgedartgt
Postby WeirdDogGuy » Sat Jul 05, 2014 9:01 pm
I'm almost done with the log splitter that I'm building so hopefully I'll soon have more time to devote to the TD build. I'm still trying to do a little everyday.
Eyeballing final clearances of the bag perch. I'm about 2-1/2 IN from the tire and about 1 IN from the frame:
WeirdDogGuy
Postby WeirdDogGuy » Sun Jul 06, 2014 9:01 pm
Band saw blades always know when it's a holiday weekend and the stores are closed because that's when they decide to let go. I knew an old time Maker who used to buy his blade stock in bulk and he'd silver solder his blades together as he needed them. He told me how to modify a door hinge for a jig and I always thought that one day, I'd try it. Today was that day. I used a flux of questionable parentage so I'm not sure how long this will stay together. I scarfed the ends like he told me, guessing at the angle. Seemed to work just fine:
WeirdDogGuy
