A sketch is worth a thousand words here....
OP827 wrote:Excuse my interuption here with some constructive critique if I may. I do not see how this sandwich kinda structurally works together. If I was doing it, I would probably try to make the steel strips structurally work together with the aluminum skin. Maybe use stick tape (VHB or similar) or glue with some Sikaflex adhesive the aluminum riveted skin to steel strips, that would ensure no galvanic contact, but structural support. Then I would put the foam under it, maybe in between the wooden blocks and flash with foam thickness.
Unless the foam has a structural skin glued to it, something like canvas or FG cloth, it does not have ANY structural properties and can only serve as insulation mostly, but it is your build and decision. Just my 0.02. Keep it going!
pchast wrote:Plastic 'insulation Washers" sold in 500 quantity for about 25$ and use most flat head screws, drill screws,
etc.. Generally 1..75 to 2" diameter, they are used to install foam onto masonry and hold stucco etc.
OP827 wrote:Oh I see you are pinning the skin to the steel, and if you figure out a way to glue the aluminum skin to foam, that would work, but could be a challenge as aluminum is not an easy material to glue and thermal expansion is another one to check. I wonder what sealant/adhesive could do that reliably and not require air to dry since the foam and aluminum are not porous? Foam will most likely to be further prepared to be glued, it is covered with silicon lubricant and nothing will stick to it without sanding or such and also the strength of the joint is weak.
S. Heisley wrote:You might try double sided tape. It would be a cheap 'try' and it only has to hold the foam until the aluminum goes on. Then, the aluminum will hold it in place. Didn't you plan on riveting the aluminum to the frame?
