... with a bunch of bracing till the glue sets.
And the water heater, 6 gallon Suburban, because it fits between the wall ribs with no modifications unlike the Atwood that is wider than the wall rib bays.
Gonefishin wrote:With the superior insulation job you're doing, you will be able to cool it with an ice cube and heat with a candle.Mighty fine.
MtnDon wrote:The nylon ones were designed specifically for securing sheet foam insulation to framing on buildings.
Hope that helps clarify that. The metal ones were desihned for a different purpose but in a CT with interior foam sheets they do pretty much like the nylon.
