jagular7 wrote:Looking great. I like how you kept the basic walls the same dimension then added an exterior clamshell to it. This adds a tad more weight, but its in the rear and probably very acceptable.
jagular7 wrote:Since you are using long piano style hinges, have you thought of a way of keeping the flip back panel and the clamshell tight? Jeep Wranglers use a rubber latch to hold their hoods down. Older CJs used a spring loaded finger type of thing. If you were to latch the flip back panel to the top and sides of the clamshell, this would provide better structural support to the clamshell and rear flip panels.
jagular7 wrote:Did you provide a 'track' system as well to keep the clamshell from distorting when lifting? Or is it structurally sound not to do that? What about the distortion at the hinge of the clamshell on the roof line? With push/pull at a corner of the clamshell to raise, this will force a distortion on the structure. In time, this transposes to the fasteners at the hinge points.
starleen2 wrote:jagular7 wrote:Since you are using long piano style hinges, have you thought of a way of keeping the flip back panel and the clamshell tight? Jeep Wranglers use a rubber latch to hold their hoods down. Older CJs used a spring loaded finger type of thing. If you were to latch the flip back panel to the top and sides of the clamshell, this would provide better structural support to the clamshell and rear flip panels.
When completed, the hatch will be supported by bolts from the side (both closed and extended). I have not installed the other two sets that are closer to the middle. When in transport the whole structure will be securely in place with the four bolts . It hard to see but the hole in the hatch when it is at rest is where the hatch will be secured with a T-nut
