Aluminum Frame RD
Re: Aluminum Frame RD
Postby RandyG » Mon Oct 28, 2013 4:04 pm
Ok so plan B was to take my framing down and start over. This time I made the shelf for the front and put a cross beam up and cut the front frame to fit under it. Then I glued some parts together and temp clamped others. Seams it worked better this way, easier to keep everything straight. Pics coming after a good garage cleaning.
Randy
RandyG
Images: 115
Postby RandyG » Tue Nov 05, 2013 7:08 pm
Back to working day shift now! Now I can get home early and make some noise without neighbors complaints. I glued and screwed the bottom half of the front. Here are some pics with and without my tongue box.
114087
114086
114088
114089
And this thing is now stuck in the garage taking up space. Its a play kitchen I made for the kids but they dont play with it any more. Its similar to a tear galley but it started as an entertainment center.
114085
Randy
RandyG
Images: 115
Postby RandyG » Thu Nov 07, 2013 5:16 pm
Wire came in the mail today! 250ft not much more than the 100ft roll so why not? Too much wire, not possible.
:twisted:
Randy
RandyG
Images: 115
Postby RandyG » Sun Nov 10, 2013 4:45 pm
Cleaning out some old junk out of the back of the garage so I pulled the tear out of the way, good time for a full picture.
114174
Randy
RandyG
Images: 115
Postby KCStudly » Sun Nov 10, 2013 8:00 pm
Looking good. :thumbsup:
Postby aggie79 » Mon Nov 11, 2013 10:54 am
KCStudly wrote:Looking good. :thumbsup:
+1 on what KC said! :applause: :applause: :applause:
Postby RandyG » Tue Nov 12, 2013 7:42 am
Thanks fellas! I got the top half of the bowed front framed out now, and started to skin the inner side until I ran out of screws. Also built a lil jig form to aid in bending the 1/4" sheets to the 17" radias. One side is in but not screwed in and the other is still in the jig, that one should be easy to attach.
Randy
RandyG
Images: 115
Postby 91kuhndog » Sun Nov 17, 2013 9:25 pm
Randy, I dont know if you've tried it yet when bending the plywood but I used boiling water (about 2 gallon) and added a cap of amonia to it. I used HF straps to pull it around in a loop and I kept bening it overthe course of a day. After I went well beyond my need curvature, I let it dry for 3 days. I went right in... BTW, I'm using a 19" radius in the nose. V/R, Brad :beer:
Our only limitations in life are purely self-induced!
My build; viewtopic.php?f=50&t=54749
91kuhndog
Images: 91
Postby RandyG » Sun Nov 17, 2013 10:37 pm
Well, that kind of what I did, just without boiling the water. Used the ratchet straps around the jig with a scrap piece clamped to the end so the straps didnt warp the ends. I should have taken a pic before taking it out today. I have a couple more to do though.
Randy
RandyG
Images: 115
Postby RandyG » Sat Nov 30, 2013 5:38 pm
I decided to not let my 4 day weekend go to waste so I got some work done today. The roof has been on my mind so I framed it up some.
114846
While at it I tried the skylight out for size.
114848
And could not resist the temptation of wiring it up and seeing how it was going to work.
114849
Works pretty well if I say so myself. I even took a magazine in there, enough light to read with. It is hard to show how much light is there through a picture, with or without the flash.
114850
It wont be hard to find this thing in a dark camp ground.
Randy
RandyG
Images: 115
Postby KCStudly » Sat Nov 30, 2013 10:05 pm
Keep at it. :thumbsup:
The only way to see your vision complete is to keep working on it. :thumbsup: :applause:
Very unique porch light. :thumbsup:
Postby RandyG » Sat Nov 30, 2013 11:49 pm
Thanks Kc, the motivation comes in spurts. Seeing how well the light worked out keeps me wanting to get more done.
Randy
RandyG
Images: 115
Postby Junkboy999 » Sun Dec 01, 2013 1:16 am
You are going to piss of a lot of squirrels trying to sleep in the trees with that light. They will be bombing your camper with nuts trying to turn it off.
:lol:
Junkboy999
Images: 52
Postby Gunguy05 » Thu Dec 26, 2013 11:32 pm
Nice build. I am planning one very similar, but slightly different. Think we are going 5 high, and going with a NT frame (modified).
I like the Al frame. That really is a weight saver. You put a lot of work into just that part of the project. Definitely a different take on the whole frame aspect of it. i like it.
Brian
Brian
Checkout my buildThe Regal Eagle Bow front for 4
Also my teardrop updates from blog on Dad Rambles
Gunguy05
Images: 6
Postby RandyG » Fri Dec 27, 2013 11:36 am
Thanks, hopefully I will be able to get back at it after the holidays. I want it camp able by March.
Randy
RandyG
Images: 115
