Woodbutcher wrote:From the top of the frame to to the roof is 68". The new torsion axle when mounted should make the overall height 83" using 14" wheels.
The frame is "WAY" modified. To lengthen it, I took 2 cross members out and bolted them into the side channel and put the rear cross piece back on. This also gives me 2 thicknesses of steel to bolt the axle back on. The steel mart place did not have a channel that would work so I replaced the 2 moved cross pieces with stock steel. Then I added a piece of 2.25 X 2.25 X 3/16th steel Square tube as a tongue extension. I want to get a tongue box up there if possible.
Users browsing this forum: azgreg and 7 guests
