Project "Deuce and a Quarter"
Re: Project "Deuce and a Quarter"
Postby adam25 » Wed Apr 18, 2012 6:46 pm
Here is another thread that was mentioned earlier that has a few trailers designed to carry the bike inside the teardrop http://www.tnttt.com/viewtopic.php?f=5&t=48139
Pretty cool idea, the gallery opens to the sides to make room to pull the bike in to tow.
The first idea in the thread has a removable galley and soft roof looks like the easiest build to do and the cheapest
adam25
Images: 20
Postby droid_ca » Wed Apr 18, 2012 10:21 pm
For hauling toys this is the one that comes to mind
viewtopic.php?f=2&t=20456
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby 225 » Thu Apr 19, 2012 11:47 am
Thanks for the input guys.
Right now my main focus is on trailer construction. Most likely just build the frame and then mount axles after I build the TD. That way I can play with the weight issue.
I was thrown a curve ball. The welder I was going to buy, I was outbid on eBay. I really thought I was going to win. I bidded pretty high. Oh well.
Well I went ahead and actually made the purchase and it is being shipped.
Everlast PowerTIG 200DX
I know how to TIG weld by the way.
So anyway, carry on!
Postby eamarquardt » Thu Apr 19, 2012 1:13 pm
Here is my approach to carrying a motorcycle. The rear bumper pulls out 30 inches. It also drops down so you don't bang you shins when you are using the galley.
More pictures in my album. I don't think I'll have sway problems if the axle is located in the proper postion.
66863
Gus
eamarquardt
Images: 150
Postby eamarquardt » Thu Apr 19, 2012 1:20 pm
More pictures in my album. I don't think I'll have sway problems if the axle is located in the proper position.
66863
Gus
eamarquardt
Images: 150
Postby 225 » Mon May 07, 2012 8:53 am
I have been home a few days. Trying to setup my welding machine right. What a pain.
I had to install my trailer hitch on my car first.
With my crappy HF trailer.
Then my wife had me paint the garage....
Now I am off to the store to buy stuff, to start building...!
Postby 225 » Mon May 07, 2012 4:52 pm
Got the deck laid down.
The size is going to be 5', 2" wide, and 10ft long. Doing the sides tonight.
Postby parnold » Mon May 07, 2012 6:18 pm
And the sawdust begins!
:applause:
parnold
Images: 302
Postby 225 » Mon May 07, 2012 10:15 pm
Yes finally!
I used the GenBen profile. I really wanted to use Aggie79's profile, but I wanted it a little longer. So this is a stretched GenBen. Since it's 10ft long.
Not bad for one day's work.
Postby 225 » Tue May 08, 2012 6:48 pm
Postby 225 » Thu Jun 14, 2012 10:18 am
Update:
Well the more I looked at the 10' long template, I didn't like it. So I scrapped that idea and made a 8' regular Genben out of masonite:
Then cut the deck down to 8' and mounted the sides.
Interior skin on....
I am wanting to build the frame myself. I haven't yet because I needed to practice TIG welding a little bit before I built the frame.
I think I have my welds good enough to build the frame. I bought some scrap tubing and welded up some joints:
I am also building my own axle, and etc... Also welding up my own aluminum boxes on the front.
More to come...
Postby Forrest747 » Thu Jun 14, 2012 10:21 am
Beautiful welds
Forrest747
Cowbell Donating Member
Images: 447
Postby KCStudly » Thu Jun 14, 2012 4:09 pm
Yup, that'll do fine.
Aluminum is a whole nuther ball of wax though. Be prepared to do some studying, then more practice. Start with some thicker test pieces and work your way down.
Postby 225 » Thu Jun 14, 2012 5:58 pm
Thanks. I've messed with aluminum a little bit. My a/c balance was off and I only had a 1/16 tungsten. But now I have a new CK torch, so things have been a lot easier.
Postby KCStudly » Thu Jun 14, 2012 10:29 pm
You know about prepping the tungsten tip for AL? Zap it on some steel and get a nice fat round globule there, that way the arc is spread out and heats the AL more evenly.
