WhitneyK wrote:Is that an El Camino in the back ground?![]()
Keep up the good work!
That it is: it's my dad's '72 project.
Robbie wrote:I don't know how much that axle is going to move when it's being towed over bumps but it looks like if you were to flip the axle it might be too close to the frame rail? It looks like there is only a few inches between the U-bolts and the frame right now. Just look out for the axle hitting the frame over big bumps. Another option is to maybe get a drop receiver and flip it over so it raises the ball? That might be a better idea so it picks the tongue jack up in case she pulls it through some big dips. That way she won't be scraping the tongue jack on the ground going over or through big dips. Even just mounting the ball on the other side of the receiver she's got now will raise the front of the tongue ~4". Maybe give that a try before you go flippin the axle. Just something to think about...
Cummins01 wrote:I don't think the welds turned out too bad (for a plumber)
Cummins01 wrote:.....And we hooked it up to my sisters truck and towed it for a short little trip around the property to make sure she can see it in her mirrors etc... She can see the tires so she'll see the fenders but still be able to see down the sides of the trailer.
KCStudly wrote:A small concern I see: Your axle U-bolts seem to have a lot of space on the sides of the springs. Don't these usually fit the axle or spring much more closely? In fact, doesn’t the spring plate usually go on the spring side with the nuts and the U-bolts wrap around the axle tube (also fitting that snuggly)?
Although they look beefy, I would be concerned about the flat part (the bottom of the 'U') possibly forming itself over the spring (overtime and cycles) and maybe resulting in them getting loose. Any concerns about that?
Just asking. I'm sure there are many ways that have been done successfully.
Junkboy999 wrote:Looks like the Danger Cart is coming along.
Ha haha
your welds look great. I jelous.
Is that a 1972 El Camino and the background there?
KCStudly wrote:Making good progress!![]()
WhitneyK wrote:Good catch KC, got me to thinking too after you mentioned it. Here's how mine originally was, so I put it back that way. Mine had the hole in the plate that aligned the axle with the pin on the springs, keeps it from moving around. Also the u-bolts fit close to the axle. (I don't have but a few inches between axle and frame. It worked out fine)
Cummins01 wrote:If it ends up hitting, it's not the end of the world, we'll just reverse it and put it back under the springs but it looks sooooo much better behind her truck being 4-1/2" lower!![]()
