Hi WeirdDogguy,
Good to see further info on your approach. I had some other comments,
but they were concerning your design done as a single-swivel-wheel set-up as that
is what it seemed like you were doing. Since that isn't what you are doing they
don't pertain - Except - I would consider locating the single-wheel to more towards
a mid-body location, or even better yet, use both of the VW wheels/suspension you
have, and tuck them in the body taper - alligator leg style - at about the "60" position
for wheel center, using the "60/40 axle location" rule of thumb. That should make it
much easier to manoever when towing. Your design is so aero that what little extra
weight that using two wheels would entail really wouldn't have much of an effect.
Meanwhile, I think your design is very singular. I had thought you were planning
on carrying all the equipment [kayak,winfsurfer,mountain bike] on the inside
at once, hence the length. So now, carrying them individually will obviously
make your trip packing tasks much easier. The design will also be quite "aero" with
the front cross-section fitting within your tow-vehicle's cross-section, and then
the nice long shallow taper to the end 'point'.
I was wondering on your build method. The 'composite torque-tube' explains alot
but I wonder if the casein glue will be robust enough ? I admit to the average ignorance
concerning glue qualities, but most that I've run across seem rather brittle, so I'm
sure you must be checking all that out. I'd guess the most common or default skinning
technique would be fiberglass cloth and epoxy.
The way your design example looks, it reminds me of the early aircraft of the 1920s with their
tubular truss and fabric covered fuselages. I'll just throw out some ideas related to that for any
benefit they may give you. I'd do a triangular triangulated base frame, with a full perimeter
bumper around it [just a tube] - like South African Off Road Caravans]
and have receivers integrated , 3per side, one on each corner, and one ahead of each wheel.
This would be useful to be able to attach various set-up/camping items to it, like leveling jacks,
tables, awnings etc. , and provide a place to tie off things to.
See: [This is one of The Best ideas I've run across on the forum here.]
TD Manufacture Suggestion: 4 Receiver Tubes? Here's Why...
http://tnttt.com/viewtopic.php?f=2&t=30925Maybe use a galvanized emt truss for body sides and roof truss members, and fit foam in the
truss spaces and smooth with greatstuff, fair out, cover with "glue-n-canvas" - OR - use bead and cove foam strips applied over the trusses [Like they are doing over hull molds on some
self-build boat web sites.], then skin. I'd also make the door somewhat wider/larger or do a
door within a door for easier loading of the bulky items. [A smaller [but larger] entry door
within an overall larger cargo door.]
Your universal joint based hitch gives me pause as It seems to rely on a very small amount
of metal to handle all the towing stresses - or are you using an extra large U-joint? I'm sure
you've more experience in that area or you wouldn't be taking that approach, ['doing so to
maybe 'see if the idea will work'?] but what extra safety factor are you bulding in? At face
value you would probably have an easier time of it all by using two wheels on the trailer,
positioned more traditionally, and some version of a multi-axis hitch like the Lock-N-Roll. [
https://locknroll.com/ ]
Vastly new designs always draw comments. Mine are meant to be constructive and hopefully
beneficial to you as you persue the build.
We'll have fun watching.
Norm/mezmo
