KCStudly wrote:I think the plan is to limit the u-joint to pitch and yaw, but to weld the shaft at either end to eliminate roll.
U-Joint looks small to me, like from a PTO of steering shaft. What is the shaft diameter? We can do a torque analysis and see if it has any chance of survival.
KCStudly wrote:The original shaft diameter would be a good indication of what the anticipated or original design load was.
So lets do some back of the napkin math here. Lacking the shaft diameter, assuming that the u-joint neck cross section is the weak link, and that it is at least mild steel (not cast iron), we can look at its ability to resist shear.
Pie are square, right? (.473/2)^2 x Pi x 24kips = 4217 lbs, where 24kips is 2/3 the tensile strength of steel. I'm using single shear based on the open geometry of the u-joints yoke.
Now don't get too excited, we still have to look at the lever arms.
Let's assume that the neck of the joint is 3/4 inch from the center. That gives us a moment of 3163 lbs-in. Still seems pretty stout compared to the projected weight of the trailer. But not so fast.
So most people miss their projected weight, some by a little, some by a lot. Let's be realistic and assume that it ends up at 1000 lbs loaded, and let's further assume that just half of that rests on the tire (...so the other half is on the u-joint, but let's not worry about that right now). So that's 500 lbs on the tire... static, not dynamic.
Now let's take that 500 lbs and see how many inches it can be offset. 3163 lbs-in / 500 lbs = 6.3 inches.At yield.
Add a minimum 1.5 safety factor (because just barely not breaking isn't okay) and we get about 4.25 inch allowable offset... static.
So that's suggesting that we might have a problem when we consider the combined stress on the u-joint from dead weight and torque, not to mention that dynamic loading can typically be as high as 10x static (I wouldn't consider anything less than 4x for dynamic).
Oh, and don't forget about torque induced by side winds.
Conclusion: I'm not a licensed engineer (so please refute any errors), but it looks sketchy to me.
So someone is bound to ask, "what's the big deal? The hitch pin on my big a%% trailer hitch is only 5/8 diameter." True dat, but it is captured in double shear, sees no torque and has 75/ct more cross sectional area.
mezmo wrote:.... Your design is so aero that what little extra
weight that using two wheels would entail really wouldn't have much of an effect.
The design will also be quite "aero" with
the front cross-section fitting within your tow-vehicle's cross-section, and then
the nice long shallow taper to the end 'point'.
I was wondering on your build method. The 'composite torque-tube' explains alot
but I wonder if the casein glue will be robust enough ? I admit to the average ignorance
concerning glue qualities, but most that I've run across seem rather brittle, so I'm
sure you must be checking all that out. I'd guess the most common or default skinning
technique would be fiberglass cloth and epoxy.
The way your design example looks, it reminds me of the early aircraft of the 1920s
Your universal joint based hitch gives me pause as It seems to rely on a very small amount
of metal to handle all the towing stresses
At face
value you would probably have an easier time of it all by using two wheels on the trailer,
positioned more traditionally, and some version of a multi-axis hitch like the Lock-N-Rol
KCStudly wrote: On one hand it sounds like you have a good understanding of what you are getting into, but on the other you indicate that you want to use stuff at hand.
The two wheel vs. one wheel "argument" is the exact thing that you explained about the fibers. Two wheels spread the loads out in exactly the same way that the multiple fibers do, spreading a larger load out over a greater area. By transferring roll from side to side on a two wheel setup, the chassis is being loaded transversely in bending, not torque; the side to side reactions transfer weight from one side to the other with center of gravity helping to "right the ship"; there is no torque load concentration at the front wall, and no torque load on the hitch or TV.
Think about the cornering characteristics of your TV and what the uni-wheel trailer will do to that. Where will the CG be vertically?
WeirdDogGuy wrote: I want 10 wheels because more is better. So should I build with 10 wheels? If not, why not? Please be specific.
