Two teardrops trailers from fiberglass modular parts
Re: Serro Scotty Sportsman Jr.styl from fiberglass modular p
Postby dogscats » Sat Sep 05, 2015 12:07 am
Serro Scotty Sportsman Jr.style
I had about 20 minuets laying out the three curves . There R24'' from a Modular fiberglass component kit. So any 1/8 ply wood will bend around the roof line.
Used a full R24'' for the front top .
On the back end 'just trimmed two small pieces from one piece of R24''. Just need to add the strait pieces .
135588
135586
Will start the wedge shape trailer this following weekend .
Will be using R48'' and some small pieces of R24'' for the front
IN the back will use the three way 90.
When I get the fiberglass "wiley windows I will know how big to make the doors.
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Re: Two teardrops trailers from fiberglass modular parts
Postby dogscats » Sat Sep 05, 2015 11:32 pm
Doing the Scotty Sportsman Jr.style. I don't' want tight bends . So will be using six R24'' curves .When I do a benroy it will have R24''in the front. I have been ask to build 2 more Jr.style shells.
so I built a jeg . I can just drop and go
dogscats
Images: 20
Postby dogscats » Sat Oct 03, 2015 12:14 am
136443
136443
136441]
I need too find out how tall the rear hatch is on a Serro Scotty Sportsman Jr . When I lay it out it seams to small it can only be 27'' high. If I make a sharper turn I can get a 32'' high hatch opening
dogscats
Images: 20
Postby dogscats » Thu Oct 08, 2015 1:17 am
After many starts here I go
. As the first trailer that I'm starting is a Serro Scotty Sportsman Jr style. The parts that I will be using are 2 ea R24'' , 1 ea R48'' that will be cut in haft & 30 feet of top flange.
#1 find where the flat to curves mark is .There a dot you have to find it's a lineament mark 136520
[img][img][/img][/img]
dogscats
Images: 20
Postby dogscats » Thu Oct 08, 2015 10:58 pm
On the first two trailers the front tops have a 24'' radius top corners. Using a square to find where the radius begins.
136550
136553
dogscats
Images: 20
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
