5x10 Squaredrop build
Re: 5x10 Squaredrop build
Postby italianub » Wed Apr 24, 2024 10:54 am
Another update (finally). More poor weather, and then getting married has delayed the build quite a bit, but we're back!
Finishing up the floor, welding the fender mounts, building the template and starting on the walls is where I'm at now. I've decided to go with smaller tires, so those are now ordered, hoping to have them installed by late next week once they get here (needed to get new brakes as well, since the bolt pattern on the existing ones is for larger tires). The galley will just be too high up using these existing tires for comfortable food prep, so dropping it down about 3 inches will certainly help.. though it will still be high up, this'll have to do!
Feel free to check out the video and/or view some pictures below!
https://www.youtube.com/watch?v=CwOSLWuaZBE
Build began Feb 10th, 2024
Build journal: viewtopic.php?f=50&t=76227
Video build journal: https://www.youtube.com/playlist?list=P ... 0ZP7TwtcT3
italianub
Postby italianub » Sun May 05, 2024 9:51 pm
Two updates since my last one! Had a BIG oopsie, I hope my fix works so I don't need to spend $300 on more BB 5x10 plywood :shock: :shock:
https://youtu.be/8lKOa3qlUxU
https://youtu.be/GNvwbPVgndQ
italianub
Postby italianub » Tue Jul 16, 2024 2:47 pm
Finishing the walls, replacing the brakes/tires, putting up the walls! I was gone for 4 weeks on my honeymoon/4th of july/covid, but I am back! More videos coming soon
Man, mistakes galore, but things are coming along. Check out the youtube videos and the photos below!
Part 8 (finishing the walls): https://www.youtube.com/watch?v=AP48-B5 ... Adventures
Part 9 (misc fixes & brakes/tires replaced): https://www.youtube.com/watch?v=-A0PCw- ... Adventures
Part 10 (Walls are up!!!): https://www.youtube.com/watch?v=QC4u54G ... Adventures
Photos!
fixing some small holes in the floor
cleaning/touching up paint on frame
replacing brakes/tires so that I am using much smaller ones to lower the trailer overall by 7 inches
new brakes, more wiring!
priming and painting the cross member between my timbren axle-less suspension
mounting the floor
cutting and prepping the lower bulkhead
first wall going up!
bulkhead installation
second wall going up
front shelf installation
looks great!
cheers!
italianub
Postby italianub » Sat Jul 27, 2024 12:56 pm
Installing countertop, upper bulkhead, supports and varnish!
video: https://www.youtube.com/watch?v=T7TUJFX7hw0
Photos!
Cutting out the upper bulkhead and countertop
Dry fit upper bulkhead and countertop
Drill/countersink countertop bracket
Dry fitting countertop supports
Varnish inside
Sliding upper bulkhead down for the last time
Galley countertop, supports, bulkheads complete
italianub
Postby italianub » Sun Aug 18, 2024 6:46 pm
Building/installing galley countertops
video: https://youtu.be/18NtHV-ld6w?si=BjWFaCK19-B0hyTW
Photos!
First mockup
Adding in adjustable shelving holes
Varnish all the pieces
Creating the rounded edges for the openings
Completed look
italianub
Postby italianub » Sun Aug 18, 2024 7:09 pm
Building/installing interior shelving, galley shelving, drawer slides - with Cousin Ryan visiting!
video: https://youtu.be/vMCRHmU0oIA
Photos!
Drilling adjustable shelving holes for interior cabinets
Creating the interior cabinet face
Building drawers for the cooler and stove/oven
Installing interior cabinet face
Finishing up galley shelving
Galley cabinets and drawers complete
italianub
Postby Wolfgang92025 » Sun Aug 18, 2024 7:24 pm
Looking good. :thumbsup: :applause:
Would you mind sharing info on the jig you used for drilling the shelf support holes?
Thanks
Wolfgang
Wolfgang92025
Images: 660
Postby italianub » Sun Aug 18, 2024 7:28 pm
Wolfgang92025 wrote:Looking good. :thumbsup: :applause:
Thanks
Thanks! Here's the jig on their website, they do have different sized pin holes I believe.
https://www.kregtool.com/shop/cabinet-s ... A3225.html
italianub
Postby italianub » Mon Aug 19, 2024 1:38 pm
Ceiling, spars, insulation, electrical! So much got done - with Cousin Ryan and Electrician Darnell visiting!
video: https://www.youtube.com/watch?v=7ZS6I0wA66E
Photos!
Cutting down the ceiling
Dry fit and installing the front wall and ceiling
Spar and insulation installation! This photo shows where I forgot to add blocking on the first two spars (fixed)
Fan framing
Blocking properly installed, insulation tape over top!
Electrical!
italianub
Postby italianub » Tue Sep 17, 2024 1:41 pm
Roof/front wall insulation, roof/front wall install, hatch spar and roof wiring!
video: https://www.youtube.com/watch?v=NrQlz1ilDPM
Insulation
Roof/front wall install
Hatch spar
italianub
Postby italianub » Tue Sep 17, 2024 1:45 pm
Filling, sanding, roof fan hole, and door creation
video: https://www.youtube.com/watch?v=h9q9hiTf8wg
Filling and sanding
Roof fan hole
Framing the doors
Screwing up the first door (window opening squared, latch doesn't work)
Doing two new good doors!
italianub
