5x10 Squaredrop build
Re: 5x10 Squaredrop build
Postby italianub » Wed Apr 24, 2024 10:54 am
Another update (finally). More poor weather, and then getting married has delayed the build quite a bit, but we're back!
Finishing up the floor, welding the fender mounts, building the template and starting on the walls is where I'm at now. I've decided to go with smaller tires, so those are now ordered, hoping to have them installed by late next week once they get here (needed to get new brakes as well, since the bolt pattern on the existing ones is for larger tires). The galley will just be too high up using these existing tires for comfortable food prep, so dropping it down about 3 inches will certainly help.. though it will still be high up, this'll have to do!
Feel free to check out the video and/or view some pictures below!
https://www.youtube.com/watch?v=CwOSLWuaZBE
Build began Feb 10th, 2024
Build journal: viewtopic.php?f=50&t=76227
Video build journal: https://www.youtube.com/playlist?list=P ... 0ZP7TwtcT3
italianub
Postby italianub » Sun May 05, 2024 9:51 pm
Two updates since my last one! Had a BIG oopsie, I hope my fix works so I don't need to spend $300 on more BB 5x10 plywood :shock: :shock:
https://youtu.be/8lKOa3qlUxU
https://youtu.be/GNvwbPVgndQ
italianub
