Kermit
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 1:22 am
This is what was left and what was used.
Left129650129649
Used129651
This cap piece was off to the sandblasters a couple of days later.
And the leftovers were cut up and sent to the scrap metal recycle depot.
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 1:26 am
More fabrication:
This is repairing the rusted out lower rear trunk seal129631
This the beginning of the area under the front package tray129635129636
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 1:44 am
This is the area under the front package tray, that will house the converter, stereo, 12V Fuse panel, drawer for laptop computer, and the boxes for the AC plugs (one for converter, one for cabin, one for ceramic heater, and one for trunk area plug. Also two 12v receptacles =cabin & trunk) 129638129637129639
This was easier to do now before I install the 38 Dodge body section to the front. Have had it on and of 50 times! :roll:
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 1:51 am
What is next?129634
This is the engine access door off a 1973 VW Vanagon that we also dragged down from out back while Ted was visiting (Can't just have Farm Guests sitting around while here :twisted: )
This will be used for the bottom of the tongue box trunk lid.....I liked the latch? And the lid was only 1" wider than the 38 Dodge lid it will be welded too (easy to narrow and will save a ton of work).
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 1:56 am
Time to round the trunk lid (Galley Hatch) corners so that I don't get a V shaped scare in my forehead while showing off the Galley at Gatherings while drinking wine. :wine: 129653129652
I just can't seem to leave anything stock!!! :twisted:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 1:58 am
Welding! So you guys want to see boring welding??? :NC 129642129656129658
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Sheddie » Fri Mar 20, 2015 2:00 am
:woohoo: Hi Brian,
Thanks for taking the time to load the photos. :pictures:
I have been through them all in your gallery. 8)
I also was looking at your tractor, did you see the one on my travel thread?
Sheddie
Images: 1129
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 2:06 am
More welding!129656
Remember all sheet metal repair welds require some serious grinding before they can be Duraglassed and body filled to make them disappear??? :roll:
The above repair still has to have the rounded corners installed to accommodate the trunk corners.
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 2:13 am
Hi Frank
Yes, I have seen these V8 Conversion kits before.....but they also made one for the US Ford flathead six motor ( we didn't have them in Canada, only the V8) which I think was much prettier! I am getting tired (it has been a long day) so the name of these kits ecapes me at the moment?? :oops:
Brian
PS
My 51 8N is named "Dixie" she does a lot of the heavy lifting for us.
"Johnny" does the real heavy stuff.
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 2:18 am
Made cuts in the body and a new mounting flange for the new 1947 Pontiac Convertible rear fenders129654129655129659
They are a different profile, plus 6" longer than the 1947 Chev fenders........but way prettier! :thinking:
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 2:23 am
Tacked on the fenders today129662129661129664
Now I can check my wheel clearance before ordering my new Dexter Torsion Axle. :applause:
I want to make custom skirts......but Sandi hates skirts. :(
Might have to conduct an online pole??? :thinking: ?
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 2:26 am
Notice the profile difference?129665129664129663
This part of the body will be reworked to make the transition smooth!
And the gas filler door will also be filled. ;)
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 2:28 am
Okay....... Brian, Sharon, Frank, and others..........can I get back to welding now! :R
Much better welder than picture down loader??????? :thinking:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Vedette » Fri Mar 20, 2015 2:32 am
Frank
It just came to me......... "Funk"......that was the name of the kits for 8N Tractors.
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Kermit
Postby Sheddie » Fri Mar 20, 2015 2:44 am
The tractor sure looked sweet, the guy had a matching pair.
Just found them on Google, the v8 and il6.
Re the skirts, stick a profile photo on for us to look at, then you can go back to welding.
Sheddie
Images: 1129
