Planning for skinning!
I have RV roof edge moldings and butyl tape for where the walls but up against the roof, front, and rear panels. However, some overlap will be necessary where panels on the same surface connect up with each other. (My 4 foot wide aluminum sheets won't be able to do a whole 5 foot tall wall without some splicing. Also, the trailer is a hair over 6 feet wide.)
What do you think about the areas in my drawing where I'm planning for the sheets to overlap? My logic was to think like a roofer, plan for water to flow downhill, and make sure a top sheet overlaps a bottom sheet (not the other way around). I can use the bender to make 45 or 90 degree bends on the roof panels, to facilitate the overlap.
How much of a sheet should be overlapped with another for a good weather proof seal? (6 inches, 8 inches?) I will be using Sikaflex to seal the sheets to each other where they overlap, and of course I will screw the overlapping seams down to cross beams underneath.
