Felixx's Superleggera - It is ROAD LEGAL!
Re: Felixx's Superleggera - cladding??
Postby felixx » Sat Apr 04, 2015 5:20 am
Atomic77 wrote:I'm glad the kids are slowing you down Felixx... they will most likely grow up and want to build their own some day. You're making memories and this time is fleeting... I know how much I miss mine. You can never get this time back mate...
Good going on the build... :thumbsup:
I know it is great to have such amazing kids.
They love the caravan already as you can see. I hope they build their own too
felixx
Images: 22
Postby felixx » Sat Apr 04, 2015 11:09 pm
Sheddie wrote:Hi Felixx, you are flying along, well done. :thumbsup:
Silly question, as you probably have this organised already. But looking at your windows, what have you got to channel the rain water outside?
Also I will be applying 'mesh' (Whitebait net mesh) insects to the outside of the doors (behind a wooden' frame' )
I think this will trap a lot of rain too
(As well as slow down sand flies)
felixx
Images: 22
Postby felixx » Sun Apr 05, 2015 11:37 pm
ummm so yeah this happened today
:D
I will cut the door out tomorrow and then do the other side..
Thanks for all the help, guidance and support so far..
felixx
Images: 22
Postby dales133 » Sun Apr 05, 2015 11:48 pm
Wooohoooo we have sides
dales133
Postby Sheddie » Sun Apr 05, 2015 11:52 pm
Milestone :applause:
Sheddie
Images: 1129
Postby felixx » Mon Apr 06, 2015 3:21 am
So I was wondering.. for the trim/ flashing over the wall/ roof join you all use Aluminium
I was wondering would PVC work? I ask because I have been exprimenting, it ripples on the side when you bend it around a curve, but a gentle blow with a heat gun and it shrinks in good and tight.
What do you fellas think?
felixx
Images: 22
Postby dales133 » Mon Apr 06, 2015 3:26 am
I recon you might be playing with fire mate.
Slightest warpage or crack and you got leaks and ruin all your hard work.
That's just my opinion though
dales133
Postby felixx » Mon Apr 06, 2015 3:29 am
thanks Dale
thats what I wanted to hear. Aluminium it is
thanks
felixx
Images: 22
Postby felixx » Mon Apr 06, 2015 3:34 am
thanks Dale
thanks
felixx
Images: 22
Postby dales133 » Mon Apr 06, 2015 3:47 am
Ulrich have rv molds and you fix them on then put a rubber strip in. Para will have the strip if ulrich don't. You can get whit trim with a black insert, might look nice against you white.
dales133
Postby Sheddie » Mon Apr 06, 2015 4:50 am
I think I would agree with Dale on the pvc.
I just used unequal right angle, 25x12. You need to have the smaller edge to the inside of the curve, but it will want to twist out a bit. Just take it slowly it will go down ok. I didn't use any screws around the edges of the side walls so didn't need to cover anything down there.
Sheddie
Images: 1129
Postby dales133 » Mon Apr 06, 2015 4:57 am
Did you rivet it on top Frank?
dales133
Postby felixx » Tue Apr 07, 2015 1:03 am
Well got a door cut out today:
And the other side cladded.. roof tomorrow??
then off to buy supplies to make the hatch and alloy trim
(scared)
felixx
Images: 22
Postby dales133 » Tue Apr 07, 2015 3:19 am
Looking good felix
dales133
Postby Sheddie » Tue Apr 07, 2015 4:05 am
dales133 wrote:Did you rivet it on top Frank?
I cut the door holes out of the ACL before I glued them on so that I could screw the doors in to help secure it to the walls and clamped everywhere else. Over the top the ACL was glued along the sides and all the beams and screwed around all the edges where they would be hidden by the alloy trim. The alloy trim was glued (the glue is a glue and sealant) and screwed with countersunk screws. The trim down the sides of the hatch (where the ACL came out past the frame) was just glued, but with a pop rivet each end.
Sheddie
Images: 1129
