OK Back to the build
If you are following this build with one of your own then at this point you will notice that there is a thousand and 1 things to do.
In the last real post (before I got sideways with the badge) I was working on the hatch guttering so I had better get back to the hatch.
THE HATCH.
Now the inside part of the gutter is a match for the struts that make up the form for the hatch.
So you will need to make up (in this case ) 4 of them.
The photo above was the first of mine in the vice being trimmed up so that the others could be cut the same.
Then what I did was place 2 of them next to the gutter and the other 2 equal distance apart in the hatch opening.
And I seem to have lost a photo of them before the cross struts were sorted in place and the cutouts for these cross struts were cut.
So jumping ahead just a photo the next step was the placement of the cutouts for the cross struts, 1 at the top (hinge area) another at the bottom at floor level (where the hatch closes too) and then 3 equally spaced across the leftover distance.
After you have you cutouts done we put the 2 outer hatch mains (gutter) struts in place with small wedges of 1/8in (3mm) timber.
These small wedges will give the hatch clearance when opening and closeing , now place the other 2 mains in there place and then measure the length between the 2 outer and cut the struts that fit into the cutouts.
When yo have them all cut place them into position and glue and screw them in place.
Now at this point I removed the frame from the TD and cleaned up any bits that were overhanging the main outer struts.
Now the next bit of the Hatch build was the 2 alloy "L" sections that fit from the outer Main struts over into the gutter.
What I did was useing 1 of the main struts before the hatch frame was put together was clamp this alloy section to the strut at the bottom of the curve and then just run it around the curve untill you get to the top, this gives the alloy most of the shape needed for it to be screwed onto the frame.
Sorry no photos of the bending ,
(FOUND IT)
but the one above will give you what is the minimum size of the alloy I don't know what is available at your local hardware store , this was at the very edge of being too small across the larger flat side for the job but it worked .
You will need to drill these alloy sections every 3in (75mm) along there full length so as to screw them in place BUT DRILL AFTER YOU HAVE BENT THEM if you drill these holes before you bend them they will kink at the drill holes.
Now put the frame and it's wedges back in place and then starting from the bottom place the angle section of the alloy in the gutter and screw it into place
As you can see by the above photo I did not have a lot of overhang when the angle was in the gutter ( just enough to screw into place).
In the photo above you can see some strips of ply 1/8thin (3mm) these were needed as the alloy added to the side height of the main side struts.
OK
Now you can undo the clamps and remove the wedges at the top as the plywood will now be placed on the frame.
My plywood, This time was ran sideways compared to the rest of the roof the reason being that the ply would bend very easy running this way and there is a tight bend at the bottom of the hatch and I did not want to put undue stress on the frame for the rest of it's life.
Here is a trick.
Whatever you are useing for a himge will need to be screwed down to the hatch after you have put the sheet of plywood on so if yoy place the ply in place and then whatever is your hinge on top and mark on the ply where the fixing holes will need to be , you will be able to fix the ply to the frame without messing up the hinge screws.
The photo above is a bit weird as I had not cut the ply at this point and the marks are for the missed hinge screw placement(where the hinge screws are not going to be)
As you can see I could not get around the bend to fix on the plywood , while it was mounted on the TD so I had to get it off and finish it on the bench (OH NO) Yes it did break a bit so I cut the section off and placed an infill on the bottom .
This meant another strut had to be made to infill the bottom of the hatch as the cut section was too short to reach the whole way down.
This is not a worry as there is another layer that will go over this section of the hatch.
"THE I CAN SEE YOU IN THE DARK BIT."
There was always going to be an alloy sheet over the bottom of the hatch (same as my other builds) This gives a more robust hatch leading edge and will be easy to see if being followed at night on the road.
I took some alloy sheet that is embossed cut it 2in (50mm) longer than the width of the hatch and about the distance of the first strut up the hatch wide (the strut gives me something to screw the alloy sheet too)
I put this sheet on the side of my bench with about 1in (25mm) overhang and then clamped it into place and then useing a block of wood bent it down and then turned it over and using a leftover section of the hatch covering ply bent it down till it was almost touching the ply.
This was then mounted on the hatch and the folded section was pushed into place on the hatch ply and (check that you have the 1in (25mm) overhang at either end ) then block and hammer it into place as tight on the ply as possible.
Cut the corners of the alloy at the corners of the hatch and then very gently fold the alloy over the sides.
At some point in the middle of all this I decided that the hatch handle was going to be on this strut as well, And I decided that it would not look good with the alloy sheet under it so I cut the top edge of the alloy sheet out so that there was room for the handle.
Now I have a Jenny (a tinsmans tool for putting a jumpup on the edge of light sheet steel and alloy ,Like on the edge of your number plate) so I ran the Jenny across the top of the alloy sheet.
I don't expect for you to have a Jenny in the back shed but the local sheetmetal worker will have one so have a talk to him (needed also for the Number plate backing plate ) so take them both down at the same time.
Yes I know ......Number plate holder will be the next post...
OK here are the photos of the alloy sheet .
then screw it down
WHEW!!!!!!!!!!!!!!!!!!!!!!!
The next step is the Hinge
I will post this now in case I lose it...
