The "Minibago" benroy continued.....
Re: The "Minibago" benroy continued.....
Postby twinight » Wed May 28, 2014 2:44 pm
The hinge is a Tilla 2000 installed by the previous owner. It's similar to a living-hinge but it uses a molded, flexible polyurethane insert as the hinge with aluminum mounting flanges. A very durable and waterproof hinge, it should take paint very well too. The next post will show how I will channel the water down the sides of the hatch once I pick up some more loctite pls10 polyurethane sealant. Great, paintable stuff for sealing the edges of the canvas and smoothing inside corners. Too bad it takes days to dry.
120726
twinight
Images: 68
Postby KCStudly » Wed May 28, 2014 2:54 pm
Postby twinight » Mon Jun 02, 2014 12:39 am
Here's the side view of the hinge when open. Any water running down should drip into the aluminum channel.
120946
120947
We also started painting the side of the trailer.
120945
Her'es the semi-finished result. I still have to paint one more layer of trees.
The darkest color looked a bit too green.
120948
120955
I also got the 100 watt renology flexible solar panel mounted onto an adjustable multi-angle frame.
It can be tilted front to back or side to side. It's riveted to an aluminum angle frame. With stays on pin connections to raise and lower each corner independently.
120951
120952
120953
120954
twinight
Images: 68
Postby KCStudly » Mon Jun 02, 2014 6:24 am
Nice, both the paint and the panel mount. Good work! :thumbsup:
Postby twinight » Fri Jun 05, 2015 7:36 pm
I realized I never posted finish pictures:
122368
122367
122366
twinight
Images: 68
