Well, despite a long break from my build to do a few other projects...I got back into the garage over the last few weeks after work and managed to get some stuff done. I finished the interior cabinets at the rear of the cabin.
I got a little overzealous in the sanding on the middle panel and went through the oak veneer, but it will be covered by the 19" Naxa TV I am putting there. It has a built in DVD player and digital TV tuner, plus it comes with both 110v and 12v power cords...sweet.
I also finished the upper shelf at the head of the cabin, the headboard storage area, as well as the housing for my electrical center. You can see I started running my wiring.
I mounted the speakers for my sound system which will consist of speakers, amp, and stereo mini jack so that we can plug in whatever source we feel like listening to.
I need to touch up the poly around the speakers as the jigsaw scratched the surface a little from the angle I had to hold it to make the full cut. The spot was a little tight and I really should have cut the holes prior to installing the board, but they made it in despite.
Here is a picture of an outlet and a blank plate that will house some 12v switches in the galley area.
Some pictures of my wire routing...daunting to some, but I find it relaxing.
Here is a close up on a porch light location on the side of my trailer showing how I marked the location to put the wire to line up with the corresponding hole in the outer layer of plywood when it finally goes on and you can see the number wrapping I put on the wire to keep track of what wire goes where when I finish up the connections.
And here is the bible, my list of what number wire is what.
Just a few wires left to pull and install the interior lights so that I can do that, but first I need to finish my ceiling. So that will be my next update. Hello again and that is all I have for the moment.
Adam
